C6 seems slower than my C5???
Now here's where I'm concerned. I've only had the C6 two days and have only been able to drive it on dry roads for maybe 10 miles so far, but the C6 doesn't seem to have the "grunt" that my C5 had. I'm probably judging too soon since there are only 185 miles on the car and I'm not getting into it all the way, other than to press it to the floor momentarily a couple of times, not taking it past 4,000 RPM.
All I know is that with traction control off, you couldn't go more than 3/4 throttle in 1st without the tires coming loose on the 99. On the C6, I tried twice pressing it to the floor just for a couple of seconds and where the 99 would definitly have lost traction, the C6 never did, and seemed to have less acceleration. And yes, traction control was off on the C6 when I tried it.
I'm hoping that maybe my perception is a few things combined, like not wanting to stay in it up to redline, the new engine developing its power higher in RPM, the new tires being a little stickier, the new engine running smoother, and maybe the dealer put in 87 octane since they filled the tank before I picked it up.
Anyone have any experience here? I love the car, but something about this new engine feels more like a Japanese turbocharged 6 than a good ol' pushrod V8. Either this thing is slower than my C5 or the feel is just so different that my SOTP meter is all out of whack.
Mike
Hopefully you've found it to be a better car overall, though. How is it in the twisties?
I wonder if my old one being a Z51 and the new one not has anything to do with speed. Is the gearing or rear ratio any different between a 99 Z51 and a 2005 non-Z51? I know the gearing is a little different in the 2005 Z51's versus the regular 2005.
Mike
Mike
1st - 2.66 - 2.97
2nd - 1.78 - 2.07
3rd - 1.30 - 1.43
4th - 1.00 - 1.00
5th - 0.74 - 0.71
6th - 0.50 - 0.57
Rear axle is 3.42 for 6-sp C6, no matter whether you have Z51 or not.
I have seen several C6 6 spds dyno around 350 rwhp so far and they seem to weigh in around 3200-3260 gassed up . After that it is simple math to some degree. Yea gearing traction and other factors weigh in but bottom line is that your 99 should have weighed around 3180 or so stock (hardtop , right?) and should have dynoed around 300+ or so stock . Those few pounds advantage is more than outweighed by the C6's much greater horsepower.
It may not FEEL that fast yet but you really have not given it the chance yet.....how well they break the tires on a particular car loose is really not the best way to tell how quick and fast they are and neither is the ole butt dyno .......
Mike
Mike
Mike
I originally posted this subject when I had only driven the car about 50 miles, only a portion of that on dry roads on a hot/muggy day with "dealer gas". Now that I've run almost a tank through it, replaced the gas with Mobil 93, and gotten a few more miles on it, it is tearing up the road like a scalded ape!
It's definitely faster than my old 99 w/Vararam now. I really think these things will be slipping past the 2002+ Z06's at the track once they've been driven a few thousand miles and properly broken in.
Mike
so maybe you need to break it in more.
Anyone have a dyno graph of a stock C5 and C6 showing the curve differences?
Mike
