Anyone Know How To Access Error Codes?
Old Sep 23, 2004 | 03:48 PM
abrimberry's Avatar
abrimberry
Cruise-In II Veteran
Default Anyone Know How To Access Error Codes?
Asked my dealer and they don't have a clue.
Need to clear check engine light. Thanks.
Old Sep 23, 2004 | 04:39 PM
LS WON's Avatar
LS WON
You already having problems with your new car?
Remember keep it factory stock otherwise you will have tons of problems and are asking for it. Lots of times it isn't the car that's bad but the people who perform the type of quality of work on them or lack of quality work.
Old Sep 23, 2004 | 04:44 PM
abrimberry's Avatar
abrimberry
Car is bone stock. Check engine light came on around 200 miles. Used the On Star remote engine diagnostic service. They told me to make sure my gas cap was closed correctly. I figured the check engine light got tripped by something like a window module didn't respond quickly enough for the main computer, etc. This was very common on my C5.
Old Sep 24, 2004 | 04:32 PM
LS WON's Avatar
LS WON
There is somebody else here on the forum that is having the same problem with the Check Engine light as well as one of his speakers and a few other things too with only 10 miles on the Corvette.
With all of these electronics and computers things have gotten more complicated and $$$ Xpensive to fix..i.e. a C-6 of today to a C-3 68 to 72 Corvettes. You would think that this is a new car there shouldn't be any problems this soon..on a 30 year old classic I can understand but the 68-72 Corvettes are easier to get fixed especially the bare engine block Corvettes with just a clean engine no wires or anything blocking access to filters, engine, etc. compared to C-5/C-6 clutter under the hood. I would think that when something does go wrong between C-3's and C-5/6's and most likely something will go wrong on the classic 68 to 72 right?
Old Sep 24, 2004 | 05:51 PM
BRCC's Avatar
BRCC
Would sure like to hear an answer to his question. "Anyone know how to access error codes" With the C5 you could display these on the DIC is there a way to do this with the C6 ???
Old Sep 24, 2004 | 06:09 PM
LS WON's Avatar
LS WON
Go to C-6 General Discussion check the one that has stereo problems.
Old Sep 24, 2004 | 06:14 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
it can not be done without a tech 2 and special adaptors. this is why you have a 3 years 36 months warranty
Old Sep 24, 2004 | 06:43 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Nah, you should be able to pull codes for the C6 in the DIC just like you could in the C4 and C5. We will just have to figure it out is all.
Old Sep 24, 2004 | 06:54 PM
Vette_DD's Avatar
Vette_DD
Nomad, I've been in the C6 section long enough to know that if there's a way to do it, you'll probably find it for us. Keep up the good work and report back when you do find it, please. Thanks.
(And state it so we can understand it).
Old Sep 24, 2004 | 08:51 PM
clem zahrobsky
Cruise-In I Veteran
GM says you need a tech2 and a "candi module " WTF ever that is.
Old Sep 24, 2004 | 09:03 PM
Erik_In_Carlsbad's Avatar
Erik_In_Carlsbad
My C6's Check Engine light turned on shortly after I left the dealership (see thread under C6/General).
The button-pushing sequence I do on my C5 to get error codes in the DIC doesn't work on the C6.
Thanks for the OnStar suggestion -- I haven't used it yet (and seeing that it's the old analog system I was beginning to think it was a royal waste of money... so much for integrating with my Verizon cell service).
The local dealership has scheduled a Tues. appt for me to check this problem, plus that the cruise control won't engage. They said that unless the engine was running rough, driving with the check engine light on shouldn't cause any problems.
-Erik
Old Sep 24, 2004 | 09:52 PM
_Nomad_'s Avatar
_Nomad_
GM said the exact same thing about the C5. I even had to show a local dealerships Corvette tech how to do it because he had no idea it could be done.
My point here is, just because GM doesn't come out and tell you about it doesn't mean it can't be done. I don't see why the C6 would be any different than the C4 or the C5 in that there is some sort of way to access error codes from the ECM. So stay tuned...
Old Sep 24, 2004 | 10:23 PM
TriStar's Avatar
TriStar
Nomad, you're probably right (I certainly hope so) but I recall C4 C5 Specialist posting something awhile back regarding this. He said the C6 uses the new GM communications data buss and that pulling codes without the Tech 2 would not be possible.
Old Sep 24, 2004 | 10:45 PM
BHP's Avatar
BHP
Well, that is a COS if true.
Old Sep 24, 2004 | 10:50 PM
minivette's Avatar
minivette
jeez... The C6 just sounds better and better.
Old Sep 24, 2004 | 11:02 PM
SWCDuke's Avatar
SWCDuke
Any dealer who sells Corvettes should have a trained tech, and proper software, and the car is still basic OBD II. Talk to the service manager, not some salesman.
If he can't give you proper confidence that they can handle the job call GM Customer Service and order them to find you a dealer who can troubleshoot and repair your car. Also, ask them why a dealer who sells you a car cannot service it.
You've got a warranty. USE IT!
Duke
Old Sep 25, 2004 | 12:17 AM
David Lasic's Avatar
David Lasic
O.K. gents, if the light is on but the car runs fine, it is most likely something that was stored from a small but repeat early learning problem.
If you wish to try to reset, disconnect the battery cable on the car. Let it set for a few minutes. Reconnect the battery. You will need to reset information set up in the DIC.
Now, simply start the car and try again. If the check engine light resets there is a problem that the dealer service center will have to diagnose.
Sometimes when brand new and learning, this can happen. A complete reset such as this will end the problem.
Good luck!!
To Anyone Know How To Access Error Codes?
Old Sep 25, 2004 | 09:53 AM
Matt Gruber's Avatar
Matt Gruber
I agree. If Onstar can read it, they must be in there somewhere.
Old Sep 25, 2004 | 10:50 AM
natejohn's Avatar
natejohn
Good luck!!
Not a "techie" here, but wouldn't you want to make sure your module was at least 100 miles away from the car when you disconnect the battery?!
Old Sep 25, 2004 | 11:10 AM
clem zahrobsky
Cruise-In I Veteran
i think the the C-5 owners manual told you how to pull the codes but the C-6 owners manual does not state this
