Tuners with HEAVY Engine Mods....How....
What am I missing?
What am I missing?
MAF systems are a little more forgiving of modest mods than speed density systems. However, they still only have the ability to change parameters within a set window, so large mods will see deminishing gains without tuning.
Todd
The MAFT can't adjust for variations from the average for those looking to adjust down the fuel ratio towards rich for power adders such as using 13:1 up to 3000rpm then dropping to 12.2-12.5 for nitrous up to redline.
The timing tuner works the same way and goes in the crank position sensor harness which allows adjustment of the spark according to base-line only. Once again you can't get +5 degrees at a certain rpm and load take out 2 at another and add 11 degrees up top like you can with edit. You can increase timing until you get knock retard then back off and this is where most guys saw 6-7 degress everywhere.
The timing tuner worked great after I got edit too. When using nitrous it turns on with a trigger switch when you turn on the nitrous arm switch pulling timing for your nitrous shot without having a permanant timing curve for N/A aplications when driving on the street. Using Auto-tap, I was able to get the 3-5 degree pull verified.
While you will never match a full dyno tune with edit you can get in the ball park and see 75% of the gains with auto-tap and a wideband such as the innovate unit.
As far as how tuners can mod without tuning altogether, adding a supercharger is quite different from adding a huge head/cam package where idle quality is an issue. A supercharger with a decent amount of boost wants to loose 3 degrees timing for every 100hp added (1 degree for each pound of boost ?....one of you forced induction guys can verify if I'm off) and it likes the pig-rich stock fuel curve. The stock curve still isnt optimum but it is safe for forced induction applications.
The other mods we have seen still dont require tuning but Andy's head and cam package is definitly going to see a big gain from it.
What am I missing?
