Mis-Machined Transmission Countershaft Snap
Old Oct 31, 2004 | 01:45 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and
safely.
Old Oct 31, 2004 | 01:52 PM
EHS's Avatar
EHS
Originally Posted by JoesC5
I thought the only caddy that had a 6-speed was(is) the CTS-V.
I drove a manual transmission CTS in 2003, so I guess it's not just the CTS -V.
Six speed.
Old Oct 31, 2004 | 02:30 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
I thought the only caddy that had a 6-speed was(is) the CTS-V. I thought it went into production during early 2004, so it would also be in it's first year of production, wouldn't it? I realize that the internals MIGHT be the same, but the CTS-V has the trans hanging off the rear of the engine, unlike the C6, so it's not EXACTLY the same transmission. Also, it's known that the C6 6-speed was internally modified from the C5's design. Does the CTS-V have the C6 internal design or the C5's? It seems, at least to me, that the C6 6-speed is in it's first year of production as is the CTS-V's.
the caddy has the same trans problem as the corvettes,the snap ring groove and there are more caddys on the fix list than C-6s
Old Oct 31, 2004 | 04:27 PM
JoesC5's Avatar
JoesC5
Six speed.
According to the GM specs I've reviewed, the 2003 and 2004 standard CTS with the 3.2L V6 has either a 5 speed manual or a 5 speed auto transmission. For 2005, the standard CTS with the 3.2L V6 has either a Aisin 6 speed manual ( which is not the same 6 speed used in the CTS-V with the LS-6) or a 5 speed auto. I stand by my original statement.
Anyway, the 2004 CTS-V which went into production in January, 2004 has the tremec 6 speed and is still in it's first year of production just as the C6 is in it's first year of production. My point is that both are experiencing first year teething problems.
Old Oct 31, 2004 | 04:39 PM
JoesC5's Avatar
JoesC5
Originally Posted by 73VetteMan
The manual transmissions are the same transmissions that have been used in the past. NOT the first time used. It was just a bad batch from the vendor and has nothing to do with the FIRST batch or the first year of the C6.
The Tremec T-56 used in the C6 is not the same as the transmission used in the C5.
"Changing gears
The 2005 Corvette continues to offer drivers thrilling driving dynamics, whether they prefer shifting or leaving it to the transmission. The Tremec T56 six-speed manual is standard and the Hydra-Matic 4L65-E four-speed automatic is optional.
Corvette engineers thoroughly revised the Tremec gear box and added proprietary technology not offered on other automakers’ high-performance transmissions. The six-speed transmission also has revised gearing when selected with the Z51 performance option. With the Z51, the Tremec is tailored with numerically higher gears to improve acceleration. Also, a lower fifth gear gives the Z51 better fuel efficiency and a higher top speed than base models. To increase durability in sustained high-speed situations, the Z51 and the base European manual-transmission models have a transmission cooler.
Smoother shifting six-speed
C6 Corvette drivers will find more pleasing, performance-oriented shifts with the six-speed transmission. They’re smoother and more precise, with shorter overall throws. The gear shift lever is now an inch shorter, and travel for all synchronizers is reduced by 10 percent. An all-new shift linkage and shift-rail bearings contribute to a more positive, confident feel. Computer Aided Gear Selection (CAGS) continues as a fuel-economy enhancement function for the manual transmission."
