Longer Wheelbase?
Old Nov 1, 2004 | 07:11 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Default Longer Wheelbase?
How was the 1.2" longer wheelbase attained? Was it a longer torque tube or a relocation of the front suspension? Thanks.
Old Nov 1, 2004 | 11:52 AM
SWCDuke's Avatar
SWCDuke
The rear wheels were essentially moved back 1.2" relative to the front wheels, and the engine was moved forward by a fraction of an inch - supposedly to accomodate the higher capacity clutch that will be required for Z06. That's why the C6 chassis is all new even though it looks the same to casual observation.
In a front engine sports car where you want maximum engine setback to avoid excess front weight distribution the engine and occupants are in competition for the same space since they both must be packaged within the wheelbase. Traditionally, sports cars have had short wheelbases, which enhance low speed tight corner handling - like autocross, but the current trend is toward longer wheelbases for better occupant accomodation with modern suspension and tire design making up for any potential loss of handling in tight, low speed corners. Longer wheelbase also reduces the inherent pitching tendency of short wheelbase cars.
Porsche 911s are still short wheelbase - 92" IIRC - but with the engine packaged aft of the rear axle centerline, it doesn't compete with available occupant space.
Duke
Old Nov 1, 2004 | 12:16 PM
JoesC5's Avatar
JoesC5
Duke
Duke, I think you will find that the front wheels were moved forward 1.4" relative to the firewall so the Northstar OHC engine would fit. Because of the larger, and longer heads and the cam drive at the front of the Northstar engine there was not enough room between the firewall and the power steering rack. Also I think you will find that the C6's LS2 engine was moved forward so a common torque tube would work on both applications.
To Longer Wheelbase?
