Lug Nut Torque
Old Nov 2, 2004 | 07:55 PM
Foosh's Avatar
Foosh
Default Lug Nut Torque
I did a quick search and didn't see this addressed before, so I thought I would share something.
The manual calls for 100 ft/lbs or torque on the lug nuts, and I hadn't checked them until tonight Just about all of them were under-torqued, most not by a lot, but they were.
My C6 now has 1800 miles, and as some of you know, they will back off a little on a new wheel. I would get them checked at the dealer or tire store if you don't have a big torque wrench.
Old Nov 3, 2004 | 12:32 AM
rwpatte's Avatar
rwpatte
Buy yourself a torque wrench. You will find that you use it. Don't depend on anybody else.
Old Nov 3, 2004 | 09:41 AM
docrings1's Avatar
docrings1
C6 FAQ Master
I use mine all the time for just this purpose, get a big one (1/2" drive) for lug nuts, etc. Also get a smaller one (3/8" drive) for doing things that can easily strip if you overtorque them (small bolts in alumimum parts, e.g. engine accessories, transmission pan bolts, etc.)
Old Nov 3, 2004 | 09:50 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Torque wrench is the way to go.
But in a pinch, you can use math. If you weigh 200 lbs, then standing 6 inches from the center of rotation will give approximately 100 ft.-lbs. of torque. Just make sure you slowly apply the weight and don't jump at all.
Old Nov 4, 2004 | 10:12 AM
rbl's Avatar
rbl
But then as soon as you drop it or it is in service for 6 months it is no longer considered accurate is it?
Had to have all of mine calibrated every 6 months to keep those kero burners in the air.
To Lug Nut Torque
