Quiz: which is "faster"?
Old Nov 17, 2004 | 12:22 AM
catpat8000's Avatar
catpat8000
Default Quiz: which is "faster"?
With all the extreme focus on 1/4 mile ets, I have a
quiz I'd like to pose.
1. Which would you rather have: a vette which runs
consistent 12.5s @ 111 mph or a vette which runs
consistent 12.9s @ 117 mph? Assume same tires,
track, car weight, etc.
2. Which vette pulls harder down the track?
Pat
Old Nov 17, 2004 | 01:09 AM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
117 is faster than 111.
12.5 is quicker than 12.9.
Quick and fast are two different things.
That being said, I would think that as close as those numbers are, you would notice little, if any, difference in seat of the pants feeling at a track.
Old Nov 17, 2004 | 01:29 AM
Brett Hunter's Avatar
Brett Hunter
My choice would be the 12.9 @117 with a new set of tires
Old Nov 17, 2004 | 01:34 AM
Chance's Avatar
Chance
St. Jude Donor '08
Trap speed is typically a better indicator of horsepower than is E.T.
Old Nov 17, 2004 | 02:26 AM
LS1LT1's Avatar
LS1LT1
True, but that full FOUR TENTHS of a second difference is a far bigger indicator of a true kick in the *** from a dead dig...I'll take the 12.5s thank you.
The truth is, as alluded to above, a 117 mph trap speed is easily an 11 second car with some tires under it.
Old Nov 17, 2004 | 07:24 AM
jschindler's Avatar
jschindler
117. The truth is, damn few people run for ultimate acceleration from a dead stop on the street. The 117 would indicate that the car is significanlty faster once rolling.
If drag racing is your thing, the lower et wins every time. But if street driving is your thing, the higher trap speed is a better indicator of how the car will really run in typical driving. BTW, I'm not above an impromtu run against someone esle on the street if conditions permit, and I can say that 98% of the time is while already rolling - not from a dead stop.
Old Nov 17, 2004 | 07:25 AM
jschindler's Avatar
jschindler
The difference between 111 and 117 is huge. You damn sure would feel that!
Old Nov 17, 2004 | 08:33 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
You'd feel it for sure. And going down the track it would look different from behind the wheel too. 6mph difference in trap speed represents a big difference in horsepower. I would also consider new tires to take advantage of that kind of power.
Old Nov 17, 2004 | 01:08 PM
bangbgC6's Avatar
bangbgC6
Default I rarely drive only a quarter mile.
I guess you could look at it this way:
It only took 12.5 sec to reach 111 mph for the first car in the 1/4 mile while it took 12.9sec for the second car to reach 117 in the same distance.
How much faster is the first car going in that same 12.9 sec. I bet a lot faster than 117mph.
I'll take the first.
Bye Bye.
Old Nov 17, 2004 | 01:22 PM
mikeyc6's Avatar
mikeyc6
Bye Bye.
You think the first car is going to go from 111 MPH to [a lot faster than] 117 MPH in 0.4 seconds? That's one helluva car! Pulling .64 G's of acceleration at 110 MPH. Now THAT'S a car!
This one is pretty simple:
12.5 @ 111: car that is set up well and getting good traction
12.9 @ 117: car with more power that needs tires.
Mike
Old Nov 17, 2004 | 02:44 PM
catpat8000's Avatar
catpat8000
Yes, the higher mph car is the one which "pulls"
harder. 117mph in the 1/4 means the car is pulling
significantly harder than the 111mph car.
Think of it this way: low ets are a function of how hard
the car launches. Trap speeds are the best indicator of
the power to weight ratio of the car.
Imagine sitting at a christmas tree. The light goes green.
You sit there for 2 seconds then launch. That same 12.9
car will now be running a 14.9 et but will still hit 117mph.
This is analogous to what happens when your wheels spin
at the launch. You are essentially "wasting" time at the
start but it won't significantly affect your trap speed.
Or look at it another way: if you spin your tire like crazy
for the first 30 feet then hook up, you are basically only
accelerating at max potential for 1320-30 feet. You lose
30 feet of track. How will that affect the trap speed? Well,
how much mph gain do you expect over the final 30 feet
at the end of the 1/4 mile? Remember you're travelling
over 115 mph. Even if you weren't accelerating any more,
you'd cover than space in 0.17 seconds. You aren't going
to add to your trap speed in 0.17 seconds when you're
already doing 115mph.
I'd take the 117mph car. It will pull much harder.
Pat
Old Nov 17, 2004 | 08:07 PM
crabman's Avatar
crabman
Wow, good way to explain it.
Old Nov 17, 2004 | 09:07 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Take into consideration the 60'. My '95 six speed is faster, but my '93 auto is quicker. The difference? How about 3 tenths in the 60'. We're talking nearly yanking the front wheels off the ground.
Your et's can vary, this past weekend, I had 5 runs, 4 were 12.50 one was 12.60, the MPH were all 107.75 with one run at 108.
Old Nov 17, 2004 | 11:12 PM
LS1LT1's Avatar
LS1LT1
Well apparently NOT, up to 111mph at least.
Old Nov 17, 2004 | 11:42 PM
mikeyc6's Avatar
mikeyc6
The difference is that the 111 MPH car "slammed" hard off the line for the first few yards (maybe 10 yards). For the rest of the ride (over 4 football fields), the 117 MPH car pulled harder. So which will you notice more? Depends on what you are looking for. The 111 MPH car pulled harder for the first 1.5 seconds of the ride while the 117 MPH car pulled harder for the last 11 seconds. Would you prefer the initial 1.5 second jolt, or the sustained 11 seconds after that where the 117 MPH car is accelerating faster?
Another way to look at it... if you do a rolling start where both cars are already going 25 MPH (or more), the 117 MPH car wins every time.
Mike
Old Nov 18, 2004 | 02:54 AM
LS1LT1's Avatar
LS1LT1
True.
But regardless of all that, in the end, who won the drag race?
Old Nov 18, 2004 | 08:33 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
The car with the higher trap speed is superior.
Not only will it kick the crap out of the other car from a roll, but its E/T can be improved simply with better shifting and/or tires.
To Quiz: which is "faster"?
Old Nov 18, 2004 | 11:55 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
In the real world I would rather be driving the car that traps at 117.
Old Nov 18, 2004 | 06:19 PM
bangbgC6's Avatar
bangbgC6
Default ??
Mike
I can't argue with that, I went on a test run this morning to test your theory and it is appearently true.
In the additional .4-.5 sec the car continued accelerating to 115-116 mph. Top speed timed run 12.9 sec 115-116 mph.
So is the difference appears to be 1 mph at the same et 12.9 sec.
The distance covered would be 1,406ft for the first car or 85 feet further in the same elapsed time.
Old Nov 19, 2004 | 02:03 PM
crand002's Avatar
crand002
I will take the higher mph and get steeper gears
