Oil Pressure
Old Dec 28, 2004 | 02:45 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
Default Oil Pressure
The oil pressure in my C6 is around 40psi. My 02 Camaro SS is around 60psi. Is 40psi on the LS2 normal?
Old Dec 28, 2004 | 03:22 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default 40 is Fine
Mine runs 36-40 at constant RPM
Old Dec 28, 2004 | 04:23 PM
C8-Vette's Avatar
C8-Vette
Mine has been around 39 lbs hot - 39/40 is normal -That Mobil 1 pumps easy! I have 2500 miles
Old Dec 28, 2004 | 07:55 PM
Brett Hunter's Avatar
Brett Hunter
Thats about where mine stays.
Old Dec 28, 2004 | 08:15 PM
crabman's Avatar
crabman
Anyone figure out yet if the gauge is a real gauge or if its controlled by the PCM like on many other cars?
Old Dec 29, 2004 | 04:35 AM
shopdog's Avatar
shopdog
The highest pressure I've seen at idle has been 51 PSI. That was just after startup, cold engine, air temp about 20F. When the oil gets up to operating temperature, pressure drops to 38-40 PSI at low to moderate RPMs, runs up to about 48 PSI at redline.
Old Dec 29, 2004 | 12:03 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
Thanks guys. I was a litle worried that it was lower than on my 02 LS1 Camaro SS.
To Oil Pressure
