Tire Question - Nail
Old Dec 31, 2004 | 07:41 AM
Turbo63's Avatar
Turbo63
Default Tire Question - Nail
The other day after having my C6 detailed, I noticed a tack nail in the rear right tire. The nail was about 1 inch in from the outer edge of the tire. I took it to a local Good Year store where we removed the nail and used the standard water/soap to detect any bubbles etc -- additionally the DIC indicated full pressure when the nail was removed. So far no issues. QUESTION: On the EMT Supercar Tires how thick is the rubber right around the outer edge? The trim nail was roughly 1/4 inch longer (maybe a tad longer). Do you believe that although no immediate flat that perhaps I now have a tire integrity issue and should do something else (get it traditionally repaired, buy a new tire, or am I ok)? Sure appreciate the feedback and insight!
Old Dec 31, 2004 | 08:23 AM
ICULUKN-C5's Avatar
ICULUKN-C5
anytime you get a patch on your tire you lower the speed rating of the tire 1 level. Your Z rated tires are rated for 186 mph After the patch your tire is now a V rating (under 149). Unless you are planning some high speed runs I wouldnt worry about it.
Old Dec 31, 2004 | 10:53 AM
mikeyc6's Avatar
mikeyc6
The way I read the message is that nothing was done to the tire other than remove the nail (no patch). If that's the case, it's impossible to tell how close to the inner part of the tire the nail was, whether it punctured any bands, etc. If it doesn't leak, it might be best to just leave it alone and monitor it. It doesn't sound like it is a precursor to imminent failure, and tires probably go through that stuff all the time where the nail is flung out naturally and you never even know about it. IMO, they are made to take that crap.
Also, and I'll put my flame suit on because I know I'll get lynched for this, but IMHO there is nothing wrong with plugging a Z rated tire. I've plugged many a (speed rated) tire with no issues even in racing and going fast. If done right, plugs can be as effective (or better) than patches and (again if done right) won't cause any further damage to the tire when you put them in. You have to consider that at 186 MPH, your wheel/tire is only turning at about 2,300 RPM. That ain't very fast, even for a 19 inch wheel with a 4 inch tall tire on it!
Mike
Old Dec 31, 2004 | 12:38 PM
jimman's Avatar
jimman
My 02 had 6 punctures all in the left rear during their life, 67,000 miles believe it or not. Never a problem, raced it drove at high speeds and still here. Just think of a non-runflat riding on sidewall till you get of road, can you trust that?
Old Dec 31, 2004 | 12:59 PM
wtdog's Avatar
wtdog
I had a screw in my left rear tire. It was repaired by the local goodyear dealer with a patch. Never allow anyone to plug a tire!
The dealer told me that due to the way they patched the tire, it was
the same as new. From previous posts, I wonder if that was BS.
Old Dec 31, 2004 | 02:08 PM
BaltimoreC5's Avatar
BaltimoreC5
When my buddy had a small nail in his tire on an 02 Z06, the Goodyear dealer would not fix it. They instead drilled a hole in the sidewall and made him buy a new tire. Not sure if this was excessive, but they cited safety and the tire perfomance.
Old Dec 31, 2004 | 05:57 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
It is one thing to say "we are not going to fix it". It is a whole other thing to drill a hole in the sidewall of a tire. I'd have a serious issue if they did that to me.
One time I caught a nail about an inch away from the sidewall. My tire guy patched it, and it was fine from there on, and I kept those tires until they wore down to the treadwear indicators.
But to the original question, it may be perfectly fine. I'd suggest monitoring the tire pressure on the DIC over the next couple of weeks. If it is losing air more than any other tire, take it in and get it patched.
Old Dec 31, 2004 | 06:27 PM
C8-Vette's Avatar
C8-Vette
Mike
Mike,
I agree with you on RTY2005 situation-I don't think he will have a problem- With regards to plugs-I have been using them since steel radials first came out,without any problems. I knows tire manufactors recommend patches, however many of the inside of todays tires are ribbed-this requires grinding smooth the surface before the patch is applied-the grinding further compromises the interigity of the tire. My repair guy uses plugs only.(of course if the hole is on the outer edge of the tire,neither a patch or plug is recommended-may be time for a new tire!
Old Dec 31, 2004 | 08:59 PM
knkayotte's Avatar
knkayotte
Originally Posted by c6vette
Mike,
I've had two plugs in my C-5 for almost two years that I installed myself. Zero problems. Other option is to have a grease monkey take my tire off, scratch my wheel, and screw up the balance. Been using plugs for years with no problems. I've used them from the fridged cold of Maine to the hot temps AZ.
Old Jan 1, 2005 | 06:29 AM
LS WON's Avatar
LS WON
Mike
186 MPH is this for all Corvettes or only the 6 spd. 3.42 rears?
How about the Z-51 auto or 6 spd. manual, and auto with 3.15's?
Old Jan 1, 2005 | 07:08 AM
pltmgr's Avatar
pltmgr
I had a nail in the outer edge of my C5's rear tire. Dealer said it couldn't be repaired. I pulled the nail out-it was in at a angle and hadn't puntured the thread. Drove another 35k on the tire with no poblems.
To Tire Question - Nail
