My map lights won't turn off
Old Dec 31, 2004 | 06:52 PM
livinitup's Avatar
livinitup
Default My map lights won't turn off
Any ideas? I plan to pull the fuse once I find out which one it is. Thanks
Old Dec 31, 2004 | 07:28 PM
crabman's Avatar
crabman
You push the **** over your left knee (the one that dims the dash lights when you turn it) to turn the cabin lights on and off.
Old Dec 31, 2004 | 07:33 PM
noel48's Avatar
noel48
St. Jude Donor '14
Old Dec 31, 2004 | 08:09 PM
livinitup's Avatar
livinitup
Thanks. Unfortunately that didn't do it. My first electronic glitch. Tomorrow I'll check the codes and maybe reset the pcm (I did find the fuse).
Old Dec 31, 2004 | 10:07 PM
Vette_DD's Avatar
Vette_DD
Be sure the switches (one on each side) on the bottom of the rear view mirror are also pushed in. In to turn the lights off, out to turn the lights on.
Old Dec 31, 2004 | 11:03 PM
joghotrod's Avatar
joghotrod
My right hatch latch was loose and the micro switch did not make contact. The hatch was closed but the lights stayed on. This could be your problem. Good luck, Jimmy
Old Jan 1, 2005 | 11:31 AM
livinitup's Avatar
livinitup
Thanks all. Just goes to show there are no stupid questions. Just stupid people that ask questions. I plugged the fuse in and pushed the buttons "in" and so far so good. I suspect I hit the switch above my knee and thought "out" meant "off." Not an electronic glitch...a brain glitch.
Old Jan 1, 2005 | 11:35 AM
crabman's Avatar
crabman
No worries man. Someone has one of these posts up in a regular fashion. I think we aught to pick one of the meatier threads and get it up in the faq.
Old Jan 1, 2005 | 04:50 PM
jschindler's Avatar
jschindler
I had the same thing happen the day I brought the car home (and so have others). I never did figure out why they came on (and stayed) to begin with. I went out and restarted the car, then made sure I properly powered it down, and took the key out of range. It seems to do strange things if you turn the accessories on without turning the engine on, then walking away from it. Twice I have had to go start the car then turn it off again to make everything happy.
Old Jan 1, 2005 | 10:17 PM
Asterism's Avatar
Asterism
how were you planning to check the codes?
To My map lights won't turn off
