AC shroud removal/reinstallation after vortex install
Old Jan 9, 2005 | 03:20 PM
c6nut's Avatar
c6nut
Default AC shroud removal/reinstallation after vortex install
After the disappointment with the BPP Vortex Air-Rammer system, Ernie has agreed that he would refund me since I was not happy, and he was unable to offer any other suggestions or solutions.
Anyways, uninstalling the unit is simple, but it now leaves us with a cut open AC shroud. I know I could just run the stock units with the cutout, but I want to put it back to stock completely.
We cannot easily get the A/C shroud removed -- does anyone have any idea how it is removed? It is mostly connected with those 'barb-style' plastic clips; which have all been removed. There are also two screws through the bottom of the bumper which have been removed. The shroud is very loose, but we can't work it out. It may be possible that the front bumper needs to removed and the shroud comes in from the bottom, but we don't want to exactly remove the bumper yet.
Also, does anyone know a source for a Shop Manual??? That is another thing that would help tremendously. Any help would be greatly appreciated! Thanks
Ted
Old Jan 9, 2005 | 06:31 PM
3X2's Avatar
3X2
Are you talking about the plastic piece that sits diagonally from the front impact bar and goes towards the radiator under where the factory air cleaner sits? Hre's the directions from the shop manual. Sorry, the pictures don't show up for some reason.
Mark
Phoenix Performance
Document ID# 1461768
2005 Chevrolet Corvette
Radiator Air Baffle Assemblies and Deflectors
Removal Procedure
Disconnect the ambient air temperature sensor electrical connector.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the outer front fascia mounting screws.
Remove the air baffle mounting screws.
Remove the RH radiator air baffle lower screw.
Remove the LH side air deflector retainer pins.
Remove the RH side air deflector retainer pins.
Lower the vehicle.
Remove the LH radiator air baffle upper retainer pin (1).
Remove the RH radiator air baffle upper retainer pin (1).
Remove the radiator air baffle.
Installation Procedure
Install the radiator air baffle.
Install the RH radiator air baffle upper retainer pin (1).
Install the LH radiator air baffle upper retainer pin (1).
Install the RH side air deflector retainer pins.
Install the LH side air deflector retainer pins.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the RH radiator air baffle lower screw.
Tighten
Tighten the bolt to 2.5 N·m (22 lb in).
Install the air baffle mounting screws.
Tighten
Tighten the screws to 2.5 N·m (22 lb in).
Install the outer front fascia mounting screws.
Tighten
Lower the vehicle.
Connect the ambient air temperature sensor electrical connector.
Old Jan 9, 2005 | 06:55 PM
c6nut's Avatar
c6nut
Thank you
To AC shroud removal/reinstallation after vortex install
