DRL Question
Old Jan 13, 2005 | 05:59 PM
bdc6's Avatar
bdc6
Default DRL Question
Im getting my C6 at the end of this month...just a simple question to you c6 owners out there...how do the DRLs work...are they at the same loctation as the turn signals?? Do they eluminate white while in DRL mode then turn amber when using as turn signal???
Old Jan 13, 2005 | 06:30 PM
Vette_DD's Avatar
Vette_DD
They are the same as the turn signals and they are always amber, whether being used as turn signals or DRLs.
Old Jan 13, 2005 | 06:43 PM
LS WON's Avatar
LS WON
Default The DRL is the light furthest away from engine on side
It is amber and is the same as the turn signal. I know because mine burnt out at 300 miles and I still can't get the part..
Old Jan 13, 2005 | 06:57 PM
James Shearer's Avatar
James Shearer
My right side also "burnt out"-no DRL and no turn signal-while awaiting the replacement it strangely fixed its self!! ? something loose rather then a burnt out bulb? Working fine so far now....
Old Jan 13, 2005 | 07:03 PM
bdc6's Avatar
bdc6
thanks guys...now only thing between me and my baby is time
Old Jan 14, 2005 | 01:55 AM
LS WON's Avatar
LS WON
Default What did you do to find out it was a bad connection?
Because it didn't go out all at the same time the DRL went first then the blinkers went out and this is on the drivers side. Where is the loose connection?
Old Jan 14, 2005 | 01:56 AM
LS WON's Avatar
LS WON
Default That is great you didn't have to waste a day and
leave your Corvette unattended at the dealership for a day.
To DRL Question
