Z06 Mufflers
Old Jan 15, 2005 | 11:35 AM
AutoCutter's Avatar
AutoCutter
Default Z06 Mufflers
I am planning to use the C6-Z06 mufflers (when they are available.) I like the idea of built in 3500rpm cutout. Does any one know if that door is mechanical-ie no electrics or just just pressure. I am planning on using the Kook's headers and the 3" cross X pipes.
Old Jan 15, 2005 | 12:48 PM
shopdog's Avatar
shopdog
The explanation I heard was that the valves are operated by vacuum, but the signal that switches the vacuum on and off comes from the computer. That's necessary because the valves are only supposed to open above 3500 RPM, so it needs a tach signal to determine when to act. The computer on the regular C6 doesn't provide that signal, but I suppose you could switch the vacuum manually.
Old Jan 16, 2005 | 11:03 AM
mikeyc6's Avatar
mikeyc6
Interesting. Where are you going to get vacuum above 3,500 RPM, or specifically, when the throttle is open? I can't think of any place on an engine where you'll develop significant/consistent vacuum at full throttle.
Mike
Old Jan 16, 2005 | 11:35 AM
bdc6's Avatar
bdc6
never mind that...I hope you will have Z06 VIN# cause thats the only way you can order ANY Z06 parts...
Old Jan 16, 2005 | 11:49 AM
shopdog's Avatar
shopdog
Mike
Same place you get the vacuum for the power brakes.
Old Jan 16, 2005 | 12:13 PM
archtop's Avatar
archtop
Corsa's do that without any Electronics .
Old Jan 16, 2005 | 12:23 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
I agree
Plus i cant imagine what gm would charge for the setup
Old Jan 16, 2005 | 05:14 PM
User 81424's Avatar
User 81424
http://forums.corvetteforum.com/showthread.php?t=992668
To Z06 Mufflers
