Now available from SCP: C6 Oracle LED Ghosted Black Replacement Side Marker Lights
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
2005-2013 C6 Corvette Oracle LED Ghosted Black Replacement Side Marker Lights
If you want to give your Corvette a great looking blackout treatment then you need to check out these custom side markers. These 2005-2013 C6 Corvette Oracle LED Ghosted Black Replacement Side Marker Lights will really change the overall appearance of your Corvette. These Ghosted LED side marker lights will blend in your Corvettes body and give your Corvette a custom appearance. These LED side markers are painted solid factory black body color for a ghosted effect.
With these ghosted side markers you will only see the red and amber lights when you are turning or have your running lights on. With this painted option the side markers will get the blackout effect without vinyl or acrylic overlays on your side markers. These Corvette side marker lights are one of the easiest upgrades you can make to your C6 Corvette and are very easy to do in your garage and do not require any real mechanical background.
Be the first with these lights designed for the 2005-2013 C6 Corvette. Oracle- Concept SMD Sidemarker lights are complete side marker replacements, for the C6 Chevy Corvette, fitted with high powered 2835 Bridgelux LEDs that produce a laser-like appearance. Installation is easy! Just pop out the factory side markers and connect the new ORACLE Concept Sidemarkers right into the stock plugs.
Package Includes:
- (2) AMBER SMD Front Markers
- (2) RED SMD Rear Markers
- Installation Instructions
Order here:
Package Includes:
Order here:
