C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] "engine drag control active"
Old May 13, 2009 | 09:20 PM
2muchhp's Avatar
2muchhp
Default "engine drag control active"
Anybody ever hear about this? Came up on my DIC a couple of times and I have no idea what it means.
Old May 13, 2009 | 09:40 PM
VetteVinnie's Avatar
VetteVinnie
Benign. Did you recently change tires? I get this occasionally after putting on the Nitto Invos with 345 rear and 275 front. It doesn't cause any problems. It's just informational in nature.
Old May 13, 2009 | 09:43 PM
mousecatcher's Avatar
mousecatcher
it means the ECU thinks there is some tire slip in decel and is cracking the throttle to reduce the engine braking effect. very common if you put taller tires on the rear (only).
if you do a search you'll find many threads about it ...
e.g.
http://forums.corvetteforum.com/c6-z...r-display.html
http://forums.corvetteforum.com/c6-z...ag-active.html
Old May 13, 2009 | 09:47 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
http://forums.corvetteforum.com/c6-z...control+active
http://forums.corvetteforum.com/off-...control+active
http://forums.corvetteforum.com/auto...control+active
http://forums.corvetteforum.com/c6-c...control+active
http://forums.corvetteforum.com/c6-t...control+active
__________________
Contact:
(e) zach@katechengines.com
Old May 13, 2009 | 10:10 PM
Zoxxo's Avatar
Zoxxo
Z//
Old May 17, 2009 | 09:46 PM
2muchhp's Avatar
2muchhp
Default New Nittos
Thanks for the reply.
Exactly perfect answer - I did just install new Nitto Invo's and the rear size of course is a bit bigger.
I must've been out driving when that series of posts came up before.
Old May 17, 2009 | 10:12 PM
mousecatcher
To "engine drag control active"
