[Z06] Do you want more gears for your MM6 equiped Z06? How about MM6 to MZ6 conversion?
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Do you want more gear from your MM6 equiped Z06?
Since there isn't a company that are making differential gears for the Z06, there is another option to get more gear for your Z06. By changing the MM6 ratio to MZ6 ratio, you have something equivalent to MM6 with 3.90 gears. The added bonus is the carbon blocking rings for the 1-4 gears that will be replacing the sintered bronze blockers that are "grabby".
Please PM me for special pricing. This conversion can be performed without the carbon blockers or bronze fork pads.
This is for TR6060 equiped 08 up Z06 only.
MM6 MZ6
2.66 2.97
1.78 2.07
1.30 1.43
1.00 1.00
0.74 0.83
0.50 0.57
My conversion package will consist of all new parts. Here is what you would get
New 1st through 4th gears
New countershaft
New tapered bearings (input; rear main; front cluster and rear cluster)
New compressed carbon blockers (1st through 4th gears)
New bronze fork pads (1st through 6th)
New main case to tailshaft housing gasket
New ZR1 pick up tube (longer to pick up fluid from the back of the case)
We are now offering the ZR1 ratio also for those who have over 700 to 800 RWHP!
MH3
2.29
1.61
1.21
1.00
0.82
0.68
New 1st through 6th gears
New countershaft
For the 06-07 Z06 owners, I do have MZ6 OR M12 ratio available in T56 but the countershaft will be a 2 piece rather than 1 piece.
MM6 MZ6 M12
2.66 2.97 2.97
1.78 2.07 2.07
1.30 1.43 1.43
1.00 1.00 1.00
0.74 0.71 0.84
0.50 0.57 0.56
MZ6/M12 conversion can be done on your T56 or on an exchange or outright basis
New countershaft (2 piece)
New bronze fork pads (1st through 6th and reverse)
-Rick
MM6 MZ6
2.66 2.97
1.78 2.07
1.30 1.43
1.00 1.00
0.74 0.83
0.50 0.57
New countershaft
MH3
2.29
1.61
1.21
1.00
0.82
0.68
New countershaft
MM6 MZ6 M12
2.66 2.97 2.97
1.78 2.07 2.07
1.30 1.43 1.43
1.00 1.00 1.00
0.74 0.71 0.84
0.50 0.57 0.56
-Rick
Since there isn't a company that are making differential gears for the Z06, there is another option to get more gear for your Z06. By changing the MM6 ratio to MZ6 ratio, you have something equivalent to MM6 with 3.90 gears. This is for TR6060 equiped 08 up Z06 only. The added bonus is the carbon blocking rings for the 1-4 gears that will be replacing the sintered bronze blockers that are "grabby".
MM6 MZ6
2.66 2.97
1.78 2.07
1.30 1.43
1.00 1.00
0.74 0.83
0.50 0.57
New countershaft
-Rick
MM6 MZ6
2.66 2.97
1.78 2.07
1.30 1.43
1.00 1.00
0.74 0.83
0.50 0.57
New countershaft
-Rick
I would like pricing on the conversion listed above...
Mike
Hmmmm wonder if theres a car we could test this on????? HMMMMMMM???? Where could we find a C6Z06 maybe a bolt on C6Z06 to see some gains from this and maybe edge out a Canadian
Supporting Vendor
WOW, that's a great idea!!! You could post the improvement on your ET after the conversion. Do you have a sponsor? Oh damn, I see that you're sponsored by RKT56! LOL
MM6 MZ6
2.66 2.97
1.78 2.07
1.30 1.43
1.00 1.00
0.74 0.83
0.50 0.57
Can you do a 6th gear of 0.74 vs the 0.57 ?
as in
2.98
1.99
1.35
1-1
0.86
0.73
this is what I would ideal like: the old Gm motorsports ratio
2.29
1.60
1.21
1-1
0.85
0.76
2.66 2.97
1.78 2.07
1.30 1.43
1.00 1.00
0.74 0.83
0.50 0.57
as in
2.98
1.99
1.35
1-1
0.86
0.73
2.29
1.60
1.21
1-1
0.85
0.76
Supporting Vendor
2.97
2.07
1.43
1-1
0.86
0.71
You are looking at MH3 (ZR1) ratios:
2.29
1.61
1.21
1-1
0.82
0.68
