C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Built T56 or New TR6060
Old 03-10-2013, 10:44 PM
FRChilln
FRChilln's Avatar
Default Built T56 or New TR6060
My 07 Z is starting to show signs of a tranny replacement. What do you guys think will be better? A semi built T56 from someone like RPM or RK OR a fresh 08+ TR6060? Either one will have the added tranny brace.
I am putting down a solid 500whp and I like to feel all the ponies and maybe the occasional drag strip.
Old 03-11-2013, 02:29 PM
Rick@RKT Performance
Supporting Vendor
Rick@RKT Performance's Avatar
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
I would install a built MM6 TR6060 with custom overdrives and be done with it.
__________________
Old 03-11-2013, 03:09 PM
Fartpipe
Fartpipe's Avatar
What he said!!!
Old 03-11-2013, 03:45 PM
JwT
JwT's Avatar
I had RPM rebuild the T56 in my 07. They do a great job and it's ready for 700hp.
Old 03-11-2013, 04:36 PM
cclive
cclive's Avatar
Any built trans is going to be better than an oem replacement trans.
Old 03-11-2013, 07:48 PM
Z06-TT
Z06-TT's Avatar
Can I get a quote on this??
Old 03-12-2013, 12:21 AM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
Me too! I just pulled mine out yesterday, WOT into 5th is a little grinding. I priced a new one and it was $3800. I am going to have this one looked at for repair.
Old 03-12-2013, 10:39 AM
Fifedogg
Fifedogg's Avatar
How much would this cost outright? I have an 07 and am curious what it would cost to switch to a 6060.
Old 03-12-2013, 12:54 PM
tigertank
tigertank's Avatar
my 10 viper came with a t6060 and it dyno 580 rwhp same for tq it has dual disc clutch does the Z have the same t 6060 and clutch?
Old 03-12-2013, 02:08 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Basically same 6060 tranny, different ratios. Clutch is completely different.
Old 03-12-2013, 02:27 PM
Supporting Vendor
Our fully built MM6 ratio TR6060 is $4,800 outright. If we get 3 buyers for the custom (.80/.63) overdrive MM6 TR6060's, we can do $4,995 outright. This unit will have all new gears.
Old 03-12-2013, 03:29 PM
tigertank
tigertank's Avatar
bummer on the clutch u sayin dodge did better than Gm lol
Old 03-13-2013, 02:22 PM
ZO ZICK
ZO ZICK's Avatar
Originally Posted by tigertank
bummer on the clutch u sayin dodge did better than gm lol
:d:d
Old 03-23-2013, 07:35 AM
Brewgu
8th Gear
Brewgu's Avatar
Hi gang. This is my first post. 07 Z06 with a T-56 17,300 mi. Suffered catastrophic transmission failure. 5th gear was worn down to little nubs. Out of warranty and I'm one unhappy camper hoping GM will assist. Dealer recommending replacing entire unit. Should I request/demand a Tr6060? Should I look aftermarket? This is a weekend driver car all stock except for K&n intake and a chip. Is the 6060 an upgrade? Will I need to replace the clutch if I change? Thanks.
Old 03-23-2013, 08:55 AM
Unreal
Unreal's Avatar
6060 is an upgrade. Make sure to flush the lines and radiator or replace them.
Old 03-23-2013, 02:08 PM
Supporting Vendor
Give us a call, TR6060 would be a better option and you can customize the over drives to suite your needs. We can also give you credit for the broken T56.
Old 03-23-2013, 06:00 PM
tim414
tim414's Avatar
St. Jude Donor '12
"If" you can get GM to help out, they likely will NOT go more than 50% of cost since it's long out of warranty....and MOST LIKELY only on original equipment. Bummer I know...hopefully they'll do more to help you out in this matter...
But, give it a try...all they can say is no....good luck. If you have to go it alone I would trade the in 56 for a 6060....
To Built T56 or New TR6060
Old 03-23-2013, 06:26 PM
Unreal
Unreal's Avatar
Rick, so if I sent in my T56 from my z6 c06, how much to get it all done up nicely.
Old 03-23-2013, 07:00 PM
Supporting Vendor
Our Basic Upgrade Package is $1,700 parts and labor.
You can see all the details on our website.
Old 03-23-2013, 07:03 PM
Unreal
Unreal's Avatar
That seems like just a rebuilt t56. I wanted to know to convert it to a 6060 with all the good options. I don't need different gearing, I like the current gearing but just want the strongest parts.
Quick Reply: [Z06] Built T56 or New TR6060
