[Z06] HELP: TPMS sensors for weld wheels
hey guys.i have an 08 z and will be installing a weld drag pack.
Fronts are 17x4.5, and rears are 17x11. I know that the rear wheels will accept the typical tpms sensors. The question is will the front? I heard from a couple of people say they will not. I have seen some different styles online. I do not want to run them w/out sensors b/c of the potential abs/traction/handling problems associated with it. I was wondering if anyone has any experience with running them in skinnies? The one I came across was the ITM rubber style which looks more promising than the regular rectangular style. I prefer the black valve stem b/c I will be powdering the lip on the wheel.
thanks in advance, C.J.
link to ITM TPMS sensor
http://www.ebay.com/itm/ITM-TPMS-Sen...JY4CeN&vxp=mtr
That sensor works pretty much like any other rubber snap in valve sensor...so if regular TPMS wont' work on welds then these won't either.
FYI....ITM makes a metal stem sensor with a black stem. Metal is better than rubber for high performance applications.
I tried the canister and it worked short distances like you said. I go for long cruises and i need another option.
The rubber sensor seems to be less bulky. I would definitely prefer a metal stem but if that rubber style works i would rock it.
Depending on the model year the TPMS sensors in a can solution ranges somewhere from sub-optimal to worthless.
There are two real options - One is pony up the bucks for the TPMS eliminator device that LG sells, the other is a company that will program out the sensors from your BCM. The hassle with the second option is you have to remove your BCM from the car, ship it there, have it programmed, ship it back then reinstall it, but it is cheaper solution compared to the LG box.
Reading the review of that option, not something I would consider.
I don't run TPMS in my welds. Never had an issue. I don't see a need for it. I can drive ~100 miles before anything happens, and even then just get a warning and hit reset once.
thanks for the info dan.
I have no problem seeing the tpms light as long as I can still run the car normal and not have any ill affects from no sensors. My buddy was doing a pull once(has weld drag pack with no sensors) and the car just cut off on him mid pull. He was getting warnings that day, and we did a long cruise too. I just don't want to deal with that potential problem.
If the White Automotive solution eliminated the lights and warnings, I'd have sent it in already.
Only thing no TPMS does is limits you so you cant select comp mode. You can still turn everything off, so I don't see the need to spend money.
Again, you are talking about a very specific use case, e.g. put your drag wheels on, drive straight to the drags (a short drive), do some passes, come straight home and then put the street wheels back on - if that is the use case, then I agree, don't spend any money on a solution.
thanks for the good advise guys. This setup is for straight line fun so you all make a valid point. I guess I'll just save the money and rock them with no sensors.
..or go around a corner at more than 45 miles per hour w/o the ABS module stabbing the brakes.
Again, you are talking about a very specific use case, e.g.put your drag wheels on, drive straight to the drags (a short drive), do some passes, come straight home and then put the street wheels back on - if that is the use case, then I agree, don't spend any money on a solution.
I leave the welds on all summer without any TPMS and no issues just the dash light.
I take 200mile trips to maine most weekends too. never an issue unless the light bothers you put a piece of black duck tape over it
I do believe there is differences between years, but on my 2006, I've driven 1000+ miles and months without TPMS, and nothing besides a warning light that you hit reset. Reading the reprogramming option, you still get that, so I don't see the need to pay if you still have to hit reset when car starts.
If I leave the tires with TPMS in garage, it resyncs every time I park, and then I can drive indefinitely without sensors as long as I don't go over 100 miles or so without resyncing.
