C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
**REDLINE MOTORSPORTS E Force Install Vid**
Old Aug 11, 2014 | 07:45 PM
Redline Motorsports's Avatar
Redline Motorsports
Default **REDLINE MOTORSPORTS E Force Install Vid**
Finally had a few minutes to whip this up......real clean setup....
Old Aug 11, 2014 | 09:00 PM
Weston's Avatar
Weston
Awesome! Looks like that installs pretty nicely. Which part needed you to pull the radiator?
Old Aug 12, 2014 | 09:16 AM
Redline Motorsports
For the heat exchanger......its shown but blends in kinda easily...
HT
Old Aug 12, 2014 | 12:30 PM
brent eb02's Avatar
brent eb02
Howard how many lbs of boost? and can it be turned up with a pulley change safely ?
Old Aug 12, 2014 | 04:31 PM
Redline Motorsports
Hey Brent!
Yes....the premise of this build was to test the system as is out of the box. Spark table for 91 octane.......
Not too mention we hot soaked the hell out of the blower. Started pull at 135 IAT and ended up at 155. The way the IAT spark retard table was setup it pulled -2.5 degrees.
That said this kit out of the box should make 580-590 wheel on the street....either way its a great system, clean install and runs great on the street!
HT
Old Aug 17, 2014 | 03:25 PM
thetruck454's Avatar
thetruck454
5th Gear
Do you notice any improvement in regards to heatsoak vs the previous design eforce used on the c6 vette?
Old Jan 30, 2015 | 10:27 PM
STEALTH 99 C5's Avatar
STEALTH 99 C5
Torquemonster !
To **REDLINE MOTORSPORTS E Force Install Vid**
