C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
For the meth heads
Old Dec 28, 2015 | 09:58 PM
RowboatLS3's Avatar
RowboatLS3
Default For the meth heads
Debating on going with either a flex fuel setup or a meth kit. Don't know enough about meth so I need some input. What is a good kit to run on our cars? Will I see a good power gain by running the meth kit? Worth the money or just stick to flex fuel? Or both?
Old Dec 29, 2015 | 12:02 PM
VictorBarron's Avatar
VictorBarron
I have a Meth kit on my pro charged 496, 68 Chevelle. Big, Big Bang for the Bucks.
I probably won't put one on my Z because you would probably need a tune.
Old Dec 29, 2015 | 10:36 PM
RowboatLS3's Avatar
RowboatLS3
Don't mind getting it tuned. It'll have to be tuned for the lower pulley anyways
Old Dec 30, 2015 | 08:51 AM
nullpointer's Avatar
nullpointer
Alky Control makes one of the best meth kits. Power will depend on how much the tune is pushed.
Old Dec 30, 2015 | 03:22 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Old Dec 30, 2015 | 11:34 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Agree on alky control..
Old Dec 31, 2015 | 07:04 PM
Cordes Performance Racing's Avatar
Supporting Vendor
I like meth a lot, but given the choice if $$ isn't an issue E85 is the far superior choice. You are not relying on a secondary system to supply the needed fuel and to keep timing up.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Jan 2, 2016 | 02:52 AM
officermartinez's Avatar
officermartinez
Originally Posted by DOUG @ ECS
Like others have said.. Tons of Corvette meth users will agree.. Alky Meth Control (Julio / ECS) kits are just awesome. We have a dual nozzle meth setup on our C7 and spray 100% VP M1 methanol. Super efficient. Very beneficial as well as reliable to the engine. Minimal maintenance. Julio's customer service is simply hands down: phenomenal! And.. as an added bonus, the added HP is very substantial when you dig into your throttle.
http://www.eastcoastsupercharging.co...tegory_id=1380
...or...
http://www.alkycontrol.com/
Old Jan 3, 2016 | 10:51 PM
Bucknut2006's Avatar
Bucknut2006
I have both on my car. Not sure what your setup is like, but I have the 32% cam lobe, LT4 injectors/pump, e85 conversion kit and Alky Control. That along with the ECS 1500 kit at 13.5 psi makes around 860rwhp.
My plan is to revert back to NA next year and just run e85 without meth.
Old Jan 9, 2016 | 02:05 PM
Higgs Boson's Avatar
Higgs Boson
It's not either or. If you are going to run FI on the C7 with anything over a base base kit then you are going to need meth. using ethanol is going to make you rely on meth even more.
Old Jan 10, 2016 | 02:42 AM
imxz28's Avatar
imxz28
Read your list of mods and appears you're not supercharged. I've not see many if anyone running meth just for the sake of adding a cooling factor and more octane. I suppose it would have a positive effect if you dyno tune to match the timing curve with the meth. I know the kit is designed to turn on with boost but I suppose Julio could customize it to turn at when zero vacuum.
Maybe someone reading this thread has seen a NA C7 with meth?
Old Jan 10, 2016 | 08:45 AM
Higgs Boson
There are NA cars that run meth but it's not generally considered worth it.....In that case I would just run E85 or maybe E50 mix with a DSteck Flex Fuel Sensor kit.
Old Jan 10, 2016 | 05:05 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
THere's a turn on **** on the back of the controller where you can set it to come on at whatever voltage from the MAP sensor that you want.
The problem with doing that on an NA setup is you need some kind of RPM window switch. If you don't have one, then when the ignition is "on" but engine is off.. it will be at atmospheric pressure and that will turn the meth system on.. so you need something to only let it come on if the engine is running.
Indeed.. that's what I would do for sure..
Old Jan 11, 2016 | 05:32 PM
robert miller's Avatar
robert miller
For the money to what you get to last on the car. This is the only way to go with a meth system.. Robert
To For the meth heads
