C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
So C7 HP guess
Old Apr 13, 2016 | 09:35 PM
NFSP's Avatar
NFSP
Default So C7 HP guess
I got a 1LT Z51 C7 2014 stingray.
Have a ECS 1500sl kit
E85 flex sensor
LT4 Z06 injectors
LT4 Z06 fuel pump
ARH LT
Snow Performance Meth kit twin nozzles
And fresh tune, running on E85
What does everyone think the power is going to be made? Haha
Old Apr 13, 2016 | 10:03 PM
jacksnorm's Avatar
jacksnorm
Assuming restrictor plate removed 700-720RWHP/620-630tq
Last edited by Steve Garrett; Apr 13, 2016 at 10:59 PM. Reason: No need to requote the OP, especially if you're the next person posting.
Old Apr 13, 2016 | 10:08 PM
NFSP's Avatar
NFSP
Restrictor plate removed, making roughly 16psi
Old Apr 13, 2016 | 10:12 PM
jacksnorm's Avatar
jacksnorm
I started to ask how many lbs of boost. That's enough boost to make atleast 800 I'd think on stock cam.
Old Apr 13, 2016 | 10:14 PM
NFSP's Avatar
NFSP
Yeah it's on the stock cam for now and stock bottom end, but not for long just for right now. So I hear 800 now
Old Apr 14, 2016 | 01:44 AM
hnaskoct's Avatar
hnaskoct
Wow 16psi on stock bottom...ooowwee
Old Apr 14, 2016 | 09:37 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
in the 800 range for sure, congrats.
Old Apr 14, 2016 | 09:55 AM
C7&7's Avatar
C7&7
At 16psi 800 for sure.
My advice is to not do the snow kit though if you can avoid it. I had the snow kit for about a year and had nothing but issues with the bad push lock fittings and nozzle leaking. Went with the Alky now and couldn't be happier. At that HP the last thing you need is a meth system issue.
Good luck with the build!
Old Apr 14, 2016 | 10:21 AM
NFSP's Avatar
NFSP
Thanks brother, the snow kit has been working great so far no complaints on my end. Ragin Racin installed it.
Old Apr 14, 2016 | 11:01 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Agreed completely, be careful, meth is fuel! Thin plastic lines are for air shocks IMHO.
Old Apr 14, 2016 | 11:38 AM
NFSP's Avatar
NFSP
Agree, that's why I wanted to go the safe route with e85 and larger injectors and pump. The meth is literally just a secondary precaution and to lower the IATs
Old Apr 14, 2016 | 11:49 AM
jacksnorm's Avatar
jacksnorm
What % E85 are you able to run before running out of injector duty?
Old Apr 14, 2016 | 11:56 AM
NFSP's Avatar
NFSP
Well the LT4 injectors are about 20% larger then the LT1s so hoping to run at least 75% before maxing, but won't know til I tune.
Old Apr 14, 2016 | 02:25 PM
thegame's Avatar
thegame
I thought the max PSI for a 1500 was 14lbs is that not correct?
Old Apr 14, 2016 | 04:05 PM
Bucknut2006's Avatar
Bucknut2006
I'm at 860 @ 13psi, however the cam really helped the torque remain flat after 5k.
Old Apr 14, 2016 | 06:15 PM
T/A KID's Avatar
T/A KID
Forget psi, that just shows restriction anyway..
Old Apr 14, 2016 | 06:16 PM
T/A KID's Avatar
T/A KID
On a manual I've made close to 700rwhp on stock cam lobe, Lt4 on e50
Old Apr 14, 2016 | 11:16 PM
NFSP's Avatar
NFSP
That's impressive brother, so the cam really made that much of a difference? What's your injector duty cycle at?
To So C7 HP guess
