C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Picking a meth kit
Old Sep 27, 2016 | 06:27 PM
c0ke's Avatar
c0ke
Default Picking a meth kit
Does it really matter which brand to use? I have an opportunity to get a snow performance kit at a good price.
Old Sep 27, 2016 | 08:18 PM
ChiefP's Avatar
ChiefP
I don't know anything about snow, but I do know every builder/installer I've talked with says they will only use alky.
Old Sep 27, 2016 | 08:35 PM
NoOne's Avatar
NoOne
Use what everyone else uses.
You have a problem and come here and ask a question you will be 1 out 300 that has something different, not going to get much help.
Plus aren't the snow kits more geared toward the diesel truck market? Concept is the same but ask someone how to wire the Alky kit and get 50 answers, ask someone to a question on wiring a snow kit and get 50 questions "Why did you buy a snow kit"
Old Sep 28, 2016 | 10:30 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Do you really want a fuel to be going through plastic hose with push on connectors that Snow uses?
No.
Alky control is simple and it works.
Old Sep 28, 2016 | 11:08 AM
TTBlueZ06's Avatar
TTBlueZ06
I like Alky Control for the pump and the controller, but I like Devils own for the Nozzles and the fittings.. The big bulky Alky control nozzles look like crap. Devils own offers a nice AN style fitting and their nozzles are really good.
Old Sep 28, 2016 | 12:37 PM
C7&7's Avatar
C7&7
I can tell you this... I started with a snow kit and completely hated it. The plastic hoses and pushin connections leak like crazy. I switched to an Alky kit and couldn't be happier.
Old Sep 28, 2016 | 12:57 PM
T/A KID's Avatar
T/A KID
Alky control makes a fantastic kit, I'm a DIY kind of guy and built a nice plate system that holds a stainless steel meth tank, 100% meth pump all stainless lines, twin nozzle, activated on psi and I have a psi transducer in line that sends a signal to my Dashlogic.
it is hidden the passenger fender well and I can fill the methh tank from the top and have visual excess, I'll post up some pics this weekend
Old Sep 28, 2016 | 03:34 PM
Unreal's Avatar
Unreal
Used almost all of them. Alky control is the most reliable, nicest kit with best support.
Other kits you will just spend a lot of money upgrading, and have a lack of support.
Old Sep 29, 2016 | 01:54 PM
Cordes Performance Racing's Avatar
Supporting Vendor
alky control. we refuse to install/sell any other kit.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Oct 5, 2016 | 12:39 PM
David@MMS's Avatar
David@MMS
Supporting Vendor
all of them can use my mounting bracket
http://www.mightymousesolutions.com/...f-ec8106a1203f
__________________
Solutions for the common gearhead #made in USA
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
Old Oct 5, 2016 | 05:07 PM
2highpsi's Avatar
2highpsi
I'm using the AEM right now tied into the factory Windshield Washer tank and level sensor - which so far has worked great. It has the push lock plastic lines, and I haven't had any problems, but I only run straight water in it or the -20 degree blue stuff.
Maybe I'll look into the alky kit, but at the same time I have no desire to run straight meth, I don't need it for fueling, just as an anti-detonate in which case straight water works better.
Old Oct 13, 2016 | 12:45 PM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
Prometh is a really nice and clean install, plus they have a custom tank to fit in the rear driver side cubby.
Old Oct 13, 2016 | 02:07 PM
joemosfet's Avatar
joemosfet
I believe Snow systems expect you to only run 50/50 through them. I'm not sure if it matters, but around here, you'll find people doing 100% meth in their C7s.
Old Oct 14, 2016 | 12:36 PM
robert miller's Avatar
robert miller
Old Oct 18, 2016 | 05:41 PM
regorih's Avatar
regorih
My .02 cents.
I been running snow kits because they're cheap in price for the past 5 years or so. This whole push lock thing about the lines popping out is plausible but never has happened to me or to the other 4 kits I've installed. When done right the lines are very hard to pull out. Anyways when it comes to the pumps I feel that they're all coming from the same distributor and are just relabeled. In fact, I know for a fact that a HUGE! distributor of fast parts here sells relabled snow kits under their name for more $$$ Lastly, I only run 100% methanol in the pumps.
Roger
To Picking a meth kit
