C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Magnuson heartbeat dedicated drive benefits?
Old 02-18-2017, 09:47 AM
Corvette4ever
Corvette4ever's Avatar
Default Magnuson heartbeat dedicated drive benefits?
I am planning to install the Maggie Heartbeat for my 17 GS within couple of months. I just saw that Magnuson now offers a version that has dedicated secondary drive. This would add a bit of difficulty to the installation as the steering rack would have to be removed in order to fight the stock crank pulley and replace with the one supplied by Magnuson
I understand that with a dedicated drive you can go overdrive and run higher boost. Is there any other advantage of running the secondary dedicated drive, compared to the version that uses the stock crank? I dont have any plans of going beyond 8 psi and would prefer to avoid the complexity of replacing the stock crank pulley during installation
Any thoughts? TIA
Old 02-18-2017, 09:19 PM
T/A KID
T/A KID's Avatar
For your boost levels you don't need the secondary drive
Old 02-20-2017, 11:31 AM
joemosfet
joemosfet's Avatar
Further, the steering rack is super easy to remove and reinstall.
Old 02-20-2017, 02:36 PM
Corvette4ever
Thank you guys. Does anyone think that there is an advantage with secondary drive related to belt wrap or engine parasitic losses?
Old 02-23-2017, 05:02 PM
2highpsi
2highpsi's Avatar
You definitely want the dedicated drive, it provides better belt wrap, better belt life, an plenty of ratio options should you ever decide to look for even more power. While you need to change the crank pulley with the dedicated drive, you don't need to break into the coolant system so the installation is about the same.
Old 02-24-2017, 06:49 AM
Corvette4ever
Thanks. That pretty much sums it up
To Magnuson heartbeat dedicated drive benefits?
Quick Reply: Magnuson heartbeat dedicated drive benefits?
