Perfecting Our Piston/Rod Combo
Former Vendor
Another set of our drop-in piston/rods for the new LT1 motors is on its way out the door. This is something you don't normally see from shop. Once we receive our kits, we check every part; gaps, clearances, etc. If we see something that can be improved upon, we do it right here before the customer gets their hands on it.
We take pride in our parts and make sure every customer gets only the highest quality. If it was our car, we would expect the same. 😉
Our drop in piston/rod combo is available now and will support 1000whp. Pretty incredible for a simple drop-in set. No balancing or pulling the motor required.
Drop in rods huh? What kind are they?
Former Vendor
We worked with CP-Carrillo to make a drop-in piston/rod combo. More info here: http://cunningham-motorsports.com/pr...bbcfecd6d8a275
Cunningham Motorsports (06-16-2017)
Received 1,762 Likes
That is wild to be told that to me as long as the piston was balanced out heaviest to the least piston. Ant, shouldn't that work But then again if you did it like that, don't know if I really would like that done to the rods that is pulling metal from them. Robert
I'm Batman..
Pro Mechanic
Personally I would have preferred for the rods to be able to be done independently so I could use them with the Vengeance Racing drop in pistons as those retain 11.5:1 CR and these are only 10.5:1 CR. Carillo doesn't have an 11.5:1 drop in combo for us that I am aware of unfortunately.
Only way to do drop in rods without matched pistons that I am aware of would be to take metal out of both ends of the rod to keep the bobweight the same. Because the forged steel is stronger and a little heavier. It can be done, but is easier to do with matched pistons.
I do know I am not going to push this c7 like I did the c5 just don't see the waste & money on parts plus really no parts yet on a lot of stuff. I will have my car back on this wed if it is close to 650 I am good on the car. Then start on the z51 to the z06 build on the car. I am prep the parts to have the body shop to paint the stuff at the moment Robert
Former Vendor
as these are a balanced set. It's not that the rod is thd same weight as stock or the piston is the same weight as stock, it's the fact that the whole assembly is. When we set out to do this and chose Carrillo, it was because we wanted a complete drop in setup for customers with force inducted applications, wanting a quick and reliable solution.
Former Vendor
I'm Batman..
Pro Mechanic
Ant
Former Vendor
Which is what I assumed. Don't get me wrong, I still applaud any development like this for the LT1. Its better than the option we had before for drop in rods - none.
I didn't know that the lengths were slightly different, so that lends even more detail as to why its a "kit". The only reason I did not go this way is because I did not wanto to drop my CR to 10.5:1. I wanted to keep 11.5:1 with my boosted application. I would be willing to bet if you worked with Carillo on an actual stabdalone drop in rod that can work with the VR pistons, or a rod and piston kit that supports 11.5:1 then many others would be flocking your way.. not that aren't already. By the way, great job on the Fore fuel system too. You guys are keeping the momentum going in the aftermarket LT1 scene!
Ant
Ant
I'm Batman..
Pro Mechanic
if there is a big enough interest, we'll have cp develop a 11.5 drop in setup, but we didn't see the interest, as most of the customers wanted to have a drop in set for boosted use. The 10.5 comp allows the tuner to run more sane levels of timing which keeps egt's down on more streetable fuels.
With the 10.5 set up over the stock 11.5 to what are you guys seeing in diff in both in higher boost & timing & rwhp over the same set up on 11.5 set up.... I do know for sure I will be doing this set up down the road for sure in the car. But just want to get some time on this for the time. Plus also want to pull the meth & do this fuel set up from you guys sooner than this just to lose the meth. Plus as soon as PRM gets it out will be doing the 3:42 gear set up with the better spider gears in it also all at once with the fuel & rear set up. Robert
I love this set! Perfect if you ask me. Doesnt matter at all to me that its a set. Works out better. Why would you upgrade one and not the other? The price, does that include install?
Former Vendor
That's just the components. Includes the correct h series bearing and rings
Supporting Vendor
we have installed these and they worked perfectly
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
Cunningham Motorsports (06-19-2017)
Looks good!
So how much would it typically cost to have these installed? Or how many hours would a shop charge? I always thought you had to pull the engine for pistons and rods.
