Boost happy intake manifolds
#43
Former Vendor
Former Vendor
More beauties gone out the door!
Will be building 3 LTx Street (c7 friendly non intercooled) intakes next weekend
2 are already sold to corvetteforum C7 Members
Cajun
on3wego
that means there is 1 still up for grabs
text 832 392 2848 if your interested
Cajun
on3wego
#47
#50
Former Vendor
No they are setup for Holley rails part number 534-224
Holley has such a good price on their rails it isn't worth our while trying to build one of our own. You can pick one up on summit, jegs, Amazon or eBay any day of the week.
Will be building another big batch of intakes this weekend.
3 C7 Street
1 Street Intercooled
1 Terminator LTx
Next weekend I'm scheduled for a couple of Coyote Intake. One in particular is being built for 2000whp (core rated to 2700hp) for a pretty mean Texas Mile car.
#51
3 C7 Street
1 Terminator LTx
3 C7 Street
1 Terminator LTx
Are the rails already drilled in proper spot for injectors?
#52
Former Vendor
Yes they are their bolt in rails for their hi ram cast intakes.
The rails are pre drilled.
Injectors to use are any 48mm (oring to oring) ls7 styled injectors. You can get 2000cc injectors in this size so you won't have a fuel issue for quite some time
#53
Former Vendor
Picked up laser parts at 0800
back at my shop and welding by 0930
Have parts for
3x LTx Terminator
3x LTx C7 Street
3x Coyote non intercooled
1x 2500hp Coyote Custom Intercooled for Boostworks Mile Car
Got the 3 ltx street bottoms welded up, 1 with port injection, 2 without (for the Corvetteforum members that ordered last week
Also started tacking 1 ltx street intercooled up that will also get port injection
Tomorrow going to port and finish all of these up as well as start on 2 Terminator Manifold (1 set of flanges short to do the 3rd)
Next weekend I'll be building 4 coyote intakes and getting that other Terminator finished up, whehhh
Things are picking up big time over here so looking at adding more people to the G1 team so we can start pumping them out more volume.
Will soon be ordering a 2nd welder and have a dedicated porter, should be getting to a point next month where we can churn out almost 10 per week if necessary!
Have parts for
3x LTx Terminator
3x LTx C7 Street
#55
Former Vendor
gotta love that tight c7 fit
That was gen 1 of our c7 intakes, latest gen of c7 manifold is tapered towards the rear, the runners all angle forward by 10* as well to create more clearance to the cowl. Old design that is discontinued had about 1/8" clearance to plastic cowl, we are now roughly 1/2" clearance
Just finished 2 with the 3rd being ported during this good ole hurricane we have going on.
#56
Former Vendor
If you notice in the rear of the plenum (new design on left, old c7 on right) the roof is lower and further forward, this gives more clearance to the plastic cowling.
All old ones worked just fine and there were zero complaints against the fitment, was just closer than my comfort levels like. Also newer designs are more one piece bent (2 pieces coming from laser shop to build the plenum rather than 8 individuals pieces that all had to be assembled and welded together)
#57
#59
Former Vendor
OHh
For those who would like to relocate their coil packs but don't want to sit and lengthen 32 wires!
I have not yet designed out a bolt on bracket for the c7 to relocate the packs to however I do have the plug and play extension harnesses!
Bracket pictured is for gen 6 camaro
