Best LT4 IAT sensor relocate for accurate meth reading?
Before I pull the trigger on a meth kit for the c7z, i wanted to know where i can relocate the IAT sensor to make it all worth while. If i got the nitrous express ported top plate for the lt4 blower, that has the 8 injectors spraying into it... and used it to run watermeth, my concern is where would I put the IAT sensor to be able to read the benefits of the meth... but where it won't also experience engine heat soak and give a false reading.
Or, is the sensor already right where it needs to be on the lt4 since it probably already measures the heat downstream of the blower compressing the air?
I don't currently know where the sensor is located
If you do the direct port there really isn't a good spot to see each cylinder or anything.
If you put it in the intake charge then IAT2 would be your best bet. Or you could move IAT1 out of the maf and past the meth nozzle. (I think the Z has IAT1 in the maf still)
Moving IAT1 out of the MAF and in the charge pipe are what most do when doing a centrifugal blower.
Right, but i have no plan to run a centri blower.
eventually, turbo perhaps. But for now, i just want to meth the stock blower and have the car tuned.
the reason I'm saying that, is because the lt4 blower is right on the engine... so if the top plate of the blower is ported for meth... there does not seem to be a great place to put an IAT sensor.
I've had others tell me that there is no sensor after the blower screws (which surprised me).
I would HOPE they are wrong and you are right. Unless of course you're saying it is upstream of the screws.
driverside rear of intake blower after rotors it's a TMAP... meaning MAP and iat built into it
If there is a iat2 in the map i can let the iat1 in the maf and take readings from iat2
If you put iat1 on charge pipe iat2 will read the same thing they both gonna read the iat cold from the meth
I'm Batman..
Pro Mechanic
Because you have the meth spray onto iat1 directly or close to so its cold and you have early warning system before it gets tooo hot. You dont want to find out late with iat2 that the meth pump took a dive lol
Either way, you missed the point of the whole post. If i inject the meth atop the blower housing... iat1 is not part of the equation.
and iat2 (or any other temp sensor) can give me real time data of the temps and pull timing accordingly. Its electronic. Its kind of quick... that near speed of light stuff.
the question is...
is there an iat sensor downstream from the injection atop the blower housing.
Ive gotten mixed answers. Ive had my thread hijacked with c6 zr1 nonsense..
i need someone who knows the answer... to answer, and everyone else to be silent until we get that answer. Thank you.
