NEW WEAPON-X Fuel Line Pump Kit w/ Return and Flex Sensor
Weapon-X Is Now Offering Our New Fuel Line Pump Kit With Return And Optional Flex Sensor.
High Flow Direct Injection for GM Generation V V8 Applications
These are designed for the new GM LT series engines. These supply the needed fuel flow for high horsepower applications and only come on when the more fuel is needed and are E85 compatible allowing higher output engines to take advantage of the octane of E85 fuel.
Features:
Features:
- Plug and Play Harness
- 375 LPH Fuel Pump
- Custom Mounting Bracket
- Custom Length Braided Lines
- Aeromotive AL fittings
- Aeromotive Fuel Pressure Regular with Return
- Billet tank fitting with feed, return
- In tank Pre-Filter
- Check Valve
- Flex Fuel Sensor (option)
See more here at: https://weaponxmotorsports.com/produ...ine-pump-kit-1
For questions or best pricing contact Eddie@weapon-x.com / 513-834-6818
Bump.
We're installing another one of our stage 3 kits right now, I should have some pics up by Monday. The pump alone in that kit will support 2000hp.
You guys ever use this to feed port injection to come in under boost (with an accessory controller), while leaving the OEM fuel system to handle needs under its hp limit?
I believe they have something in the works right now, and if I'm not mistaken Ben mentioned in another thread it would be elaborated more in a couple weeks, very exciting things to come I'm sure.
sales @ WXM (11-29-2017)
^^Says the guy who is dropping off his '17 Z06 next week for our port injection kit.
Haha , you busted me !
New pump options are now available.
vetteZpilot (12-19-2017)
