Hi guys
I have 2014 C7 with pro charger super charge. I’m having the problem with the oil leak. And this is because of the high pressure. I did install oil catch can and still?
One of the guys suggested to install low pressure piston/ROCKERS and cams
Do you think this is? If yes what brand and the size.
I want it to fit the stock size.
Thanks guys.
Have a nice 2018
Pistons, rockers, and cam have nothing to do with oil leaks due to high pressure. The blower does. You need to vent the crankcase better. What catch can do you have?
Hi guys,
I have then Elite catch can and I got the LMR Catch can and breather I will install it later.
So you think the LMR catch can will solve the problem?
Thanks Guys.
We are going to need a loooooooooot more detail on the car to help you. How much boost? What head unit? What other mods? Where is the leak? Picture of your vent setup. Sounds like "one of the guys" is trying to get you to spend money unnecessarily. Assuming he works at the shop you had the car built.
Hi guys,
Thanks Guys.
Install the LMR breather asap. That will stop the issue from progressing. Post pictures of the LMR tank and links so we know whoch "version" you have as there was more than one. Also post pics of the leak area please.
Hi guys,
Thanks Guys.
To me for any car per say the Elite can is not worth putting on a car. Maybe a N/A with a problem for oily just to help catch some of it any way. Like Ant has said post pic's of the one you have plus if it don't have LMR on it, it is not a LMR can some guy in here not long ago trying to sell a can from a diff vendor that a few of those cans was made up wrong & didn't work.
Post pic's Plus LMR has the install up now on the site are in a post. You have to install it diff on the car from a N/A set and a blower set up..
