C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boosted with cats
Old Jan 13, 2018 | 05:47 PM
John Micheal Henry's Avatar
John Micheal Henry
Default Boosted with cats
My installer/tuner told me the A&A Ti with meth will mess up the cats on my ARH X-pipe. What have you guys experienced? Thanks
Old Jan 13, 2018 | 08:22 PM
robert miller's Avatar
robert miller
If stock cats they will be eat out within 2 yrs if you drive the car as a daily driver. If the aftermarket should last a little longer.
Bad thing is all that crap those honey cone like stuff will end up in the muffler. It did my c5 only reason I know it is that had a good amount of that stuff in the mufflers.. Robert
Old Jan 15, 2018 | 01:36 PM
C7&7's Avatar
C7&7
Yea Robert is right. Long term having cats on a boosted car is going to eventually have issues. If you can live without cats just pull them off.
Old Jan 16, 2018 | 02:40 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
C6 but I have the opposite perspective, LS7 cats never gave me any issues, multiple 1/2 mile events, etc. No issues. Maxed out ECS kit, meth, 93 originally then switched to E85. Everyone said they wouldn't last but so far they have. Aftermarket LT cats have survived also, though it's clear they aren't nearly as effective as the factory stuff. Still stink for a while when cold and a little bit even when hot.
I'm sure eventually they will cause issues but I would rather have issues than smell all the time. I'm super sensitive to exhaust smells for whatever reason so for me, I prefer having them
Old Jan 17, 2018 | 10:10 AM
sales @ WXM's Avatar
sales @ WXM
It really depends on the power level, not necessarily the mods. The ARH cats are tough, but they do have a limit. Around 650-700rwhp is usually the max power output you can flow through those cats before you run the risk of them failing.
If you are going to exceed that power level I would go catless, if cats are required due to emissions you can run the KOOKS green cats or the Vibrant GESi cats. Neither of those should fail, even with high HP applications.
Old Jan 17, 2018 | 10:38 AM
John Micheal Henry
Eddie, My tuner/installer said the rwhp would be 625-675 with a conservative tune. Just to be safe I'll have the cats removed. Are the cats on the ARH x pipe weaker that the Kooks?? Thank you for your time and reply..
Old Jan 17, 2018 | 11:40 AM
sales @ WXM
The ARH and standard KOOKS cats are of equal quality. KOOKS however, does offer their upgraded "Green Cat" which you can make 1000hp through. Cost for Green Cats is around $800 pair.
Old Jan 17, 2018 | 11:50 AM
John Micheal Henry
Eddie, If it were you car would you remove/replace the cats?
Thanks again for your time..
Old Jan 17, 2018 | 12:26 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I don’t know that I would be concerned about only the cats themselves failing. It’s part of a bigger picture. If the cats gets too hot at melt, they can clog the exhaust and block the passageway for exhaust getting out. Which can cause major engine failure. For that reason I pulled my cats.
Old Jan 17, 2018 | 12:46 PM
sales @ WXM
I personally would remove them. Removing them is all around healthier for the engine.
No problem John!
Old Jan 17, 2018 | 02:38 PM
yonson's Avatar
yonson
Cats can live on high HP boosted applications, however in order to do so you need to make sure COT is calibrated correctly which most tuners just turn off...
Old Jan 21, 2018 | 07:14 AM
LAYNLOW's Avatar
LAYNLOW
These guys (WeaponX) truly know their stuff!!
No problem John!
Old Jan 22, 2018 | 09:17 AM
yonson's Avatar
yonson
Other than the fact that it's illegal to do (in all 50 states) on a vehicle that's driven on the street. The EPA is already trying to shut down the aftermarket industry, don't give them any more ammo to do so...
Old Jan 22, 2018 | 11:32 AM
sales @ WXM
LOL you know you are in the Forced Induction/Nitrous section right? Most builds you come across in here are going to be up fitted with "illegal" exhaust.
As you can see above I gave an emission compliant option to the person that was asking for advice. If he chooses to go that route, then so be it.
I am probably one of the more the environmentally conscious car enthusiasts you will meet. Rather than trolling me, or the company I represent about emissions and legalities, you should go down you the local courthouse and troll the guys on the 10am docket looking for parking in their V6 Dodge Carvan's running on 4 cylinders.
Old Jan 22, 2018 | 01:42 PM
yonson's Avatar
yonson
I'm sorry if you feel that way, however I'm not trolling you or your company. CARB and the EPA are monitoring most of the enthusiast forums these days, and are using this for ammo to shut down the aftermarket. Up until recently they have been focusing mostly on the
diesel market, however they have started going after gas vehicles now.
I'm quite aware that the majority (98%+) of gross polluters are vehicles that are in an ill state of repair, however you know as well as I do that the government isn't smart enough to know that...
Old Jan 22, 2018 | 06:02 PM
sales @ WXM
No harm, no foul. I apologize that I misinterpreted your comment!
We do not have emissions testing where Weapon-X resides here in Ohio, so I don't hear much about it. I had no idea that CARB and the EPA were monitoring the forums or really cracking down anywhere other than the usual CA.
Old Jan 22, 2018 | 07:19 PM
John Micheal Henry
^^^ Thanks again Eddie for your time and reply..
To Boosted with cats
