C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Timing
Old Feb 5, 2018 | 10:35 PM
Travis86442's Avatar
Travis86442
7th Gear
Default Timing
Im running 10 psi boost .at wot Im getting 8 to 9 degrees timing is this bad ?I'm runnig sd tune
Old Feb 5, 2018 | 10:48 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
What are you commanding? With aftermarket boost applications, total spark is between 9-15. Its not as high as a stock forced induction calibrations. You might have Spark modifier removing some timing
Old Feb 5, 2018 | 11:02 PM
Travis86442
7th Gear
I'm not realy sure my tunner set it up maybe I have the torque management pulling some timing .
Old Feb 6, 2018 | 09:58 AM
yonson's Avatar
yonson
This question isn't really answerable with the provided information. What fuel are you running? What is your Lambda? IAT? ECT? etc... There are situations when that could be good or bad, but with the given information that's impossible to tell. Have you asked your tuner?
Old Feb 6, 2018 | 10:43 AM
Travis86442
7th Gear
I'm running 12.7 af wot it goes from 10.1 to 12.7 when i mash the gas yes it' kinda lean .40 psi at the regulator and holds 40 psi under boost iat are 80° if ambent temp is 75 ° timing us 16 ° when at a stop light. Plugs look good no knock or sign of pre ignition I'm running 91 pump gas
Old Feb 7, 2018 | 10:05 PM
Cordes Performance Racing's Avatar
Supporting Vendor
on 10 psi w/ meth I would expect 9-10 degrees on a 91/meth car. and why the hell are you tuned in speed density!?!?!?! the maf's read to the moon on these cars, please tell me you're not an auto in SD.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Feb 7, 2018 | 10:18 PM
JHEBERT's Avatar
JHEBERT
No kidding Joe, he’s gonna need a tranny soon...
Old Feb 8, 2018 | 01:40 PM
robert miller's Avatar
robert miller
With no more boost & fueling on this in the car. I would be looking for a diff tuner for sure cause the only reason that tuner is telling you to do SD tune is for him to play & him get more info to help him only on some big HP cars for him not to look so stupid..
To Timing
