C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Switching to a procharger instead of vortech
Old 03-06-2018, 02:43 PM
Silverboost
Silverboost's Avatar
Andy even has a ysi on his personal Z06.
Old 03-06-2018, 03:04 PM
black_c7
black_c7's Avatar
Originally Posted by algZO6
YSI will walk the D. Did you call Andy or Josh to help you with the problem? I have hit 30 psi with an 8 rib and had zero slip.
Yes we tried everything but unfortunately nothing worked, i got the 10 rib to get rid of the belt slip but it didn’t work, I also know like 5 ppl with the same problem
Old 03-06-2018, 05:04 PM
0D3PE
Former Vendor
D3PE's Avatar
We are currently testing an A2W system for the Procharged C7 guys!
Will be released to the public if testing goes well
Old 03-09-2018, 03:21 AM
black_c7
black_c7's Avatar
Is it gonna be a 3” or 3.5”?
Old 03-09-2018, 04:51 AM
on3wego
on3wego's Avatar
Cost on this?
Old 04-29-2018, 04:17 PM
black_c7
black_c7's Avatar
F1X will be in the car by mid may and hopefully we can make all the power without any belt slip, need to figure out what pulley combo to make 20psi on a stock cubic lt1, and what belt to run
Old 04-30-2018, 01:17 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Originally Posted by on3wego
Need to ditch the d1sc and go f1a94
No dam way you had belt slip on a 10 rib with a YSI head unit. Something else was bad wrong if you did all I have to say on that.
Old 04-30-2018, 01:19 PM
robert miller
Originally Posted by ajrothm
The D1sc will usually max out around 800-850 rwhp in a stick car... I have seen some claim to make more but...That's the norm.
YSI on the other hand is usually good for 1000-1100 rwhp on a good combo.
I would have sent the YSI in to Vortech for an inspection....
D1SC is a damn good blower but, you ain't gonna make YSI power with one. Hell I had an F1R and couldn't make YSI power.
F1A-94 is the way to go for 1k rwhp.
This c7 seems to love the F1A-94 set up..
Old 04-30-2018, 01:20 PM
black_c7
black_c7's Avatar
Its was either a belt slip or belt stretch, all people I know who ran the same kit i had ran the same problem where they always had belt slip, nobody made the power the ysi should put to the wheels when running the ysi on that kit
Old 04-30-2018, 05:20 PM
C7&7
C7&7's Avatar
You've hit 30 psi with a YSI? What pulley combos??? I've never seen more than 22 with my 2200X and 2.95 upper.
Old 04-30-2018, 05:24 PM
algZO6
algZO6's Avatar
8"/2.6" DA was -1200' so that helped quite a bit.
Old 04-30-2018, 05:25 PM
black_c7
black_c7's Avatar
His engine might be small and little higher compression that why, yours is probably bigger engine and lower compression
Old 04-30-2018, 05:26 PM
  #33
black_c7
black_c7's Avatar
What is your engine combo and what compression and reving it to what rpm
Old 04-30-2018, 05:43 PM
  #34
algZO6
algZO6's Avatar
stock cube LS2 and 10.5 comp. shift at 7k
Old 05-11-2018, 11:21 PM
  #35
robert miller
Default ttt
^^^ his car is just bad *** & hooks like crazy. Robert
Old 05-21-2018, 08:48 PM
  #36
black_c7
black_c7's Avatar
Finally finished the car with the f1x and belt slip problem that i h had before with the ysi is solved,
I really like that now it doesnt have any belt slip and can feel the power progressively, but didnt like that it doesn’t have the torque or the pull that the ysi had, it made 803 on 13 psi pump gas, that was on a 4.75 pulley at 7000 rpm, impeller speed is at 66500 rpm,
With the ysi get broken it made 865 with 21 psi with alot of belt slip
F1x made 803 on 13 psi
Both on pump gas
Old 05-22-2018, 08:55 AM
  #37
Dave01GT
Support Corvetteforum!
Dave01GT's Avatar
Both on pump gas
did you just swap out the vortech bracket for the Procharger bracket? Did it line up with your vortech piping?
To Switching to a procharger instead of vortech
Old 05-22-2018, 08:57 AM
  #38
black_c7
black_c7's Avatar
Didn’t line up, had to modify the piping and add some reducers
Dave01GT (05-22-2018)
Old 05-30-2018, 11:21 AM
  #39
Dave01GT
Dave01GT's Avatar
My belt is slipping now too over 6,000rpm. I have a 10 rib, 8.3 lower, 2.75 A&A grip upper. I'll ask Josh/Andy, but the correct way is to lock out spring loaded, pry over manual tensioner, tighten, then unlock spring loaded? Red is RPM, Yellow is Map which should continue up with RPM but is sloping back down. Don't know why the pic wont go right side up.
Old 05-30-2018, 11:28 AM
  #40
black_c7
black_c7's Avatar
Dave DONT DO THAT, it will put a ton of load on your head unit bearings and will break your ysi, mine broke because of that and it had lower than 2500miles on the unit (everything was broke), try to send your idler to andy and let him set up ththe spring tensioner on the soft spring setting, what you are have is belt stretch at first them you are having belt slip, try the grip tech pulley I think that will work better than putting a pry bar and applying a ton of load on the head unit
Dave01GT (05-30-2018)
Quick Reply: Switching to a procharger instead of vortech
