C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Ysi pulley combination and boost level
Old Jul 30, 2018 | 11:50 PM
3honkz's Avatar
3honkz
Default Ysi pulley combination and boost level
Built short block, stock lt1 heads. Lt4 injectors, hpfp and cpr low side. As of now on 3.4 upper pulley and 8.25 lower I am seeing 10.5 pounds and 12.5 pounds with no filter. My goal is to get into mid to high 900s with this setup on 93 and meth. I was suggested to go with 3.0 crossed slotted pulley from A&A since I am still on 8 rib setup for now. My question is will 3.0 upper will be good enough to achieve my goals? Eventually I will go with 10 rib setup.
Old Jul 31, 2018 | 12:25 AM
black_c7's Avatar
black_c7
If you dont have any belt slip that will do it for you for sure, be ready to fight belt slip, go get you a zpe griptech pulley
Old Jul 31, 2018 | 07:41 AM
3honkz's Avatar
3honkz
belt slip is the issue I am trying to stay 3.0 and up. I went to griptechs website and looks like they only sell 2.95 for vortech or 3.8. Can they make one for us if we order ahead of time?
Old Jul 31, 2018 | 11:55 AM
C7&7's Avatar
C7&7
I ran the 2.93 upper and see around 20-21 psi. I do run the 10 rib though. I am running the 2200X though...Although it is the YSI-B not sure if ECS develops different size pulleys for it. I got the 2.93 and the 3.25 and the 2.75 when I bought the blower from them. All in 10 rib, but that shouldn't matter when it comes to the pulley size options,
All you need is the 3.25 probably to achieve your 900 wheel goal. You should see 16-18 with the 3.25 upper. You should be fine with 8 rib and that upper.
Old Jul 31, 2018 | 12:14 PM
3honkz's Avatar
3honkz
that 10 rib is what helping u not get the slip. And thanks for the info.
Old Jul 31, 2018 | 03:24 PM
robert miller's Avatar
robert miller
If this motor is anything at all like the LS set up your motor will do great with the 2.75 pulley on the YSI over spin that puppy & let it dig. this on a stock ci LS motor will get you just a little over 1,k to the wheels..
Old Jul 31, 2018 | 04:55 PM
ysb02's Avatar
ysb02
With a 3" / 8.25" pulley you'll be pushing 64,515 rpm on the blower near 6800 rpms. That's ~97% of the max rpm rated by Vortech (it can go higher though). That should be enough to make 900rwhp
Old Jul 31, 2018 | 05:37 PM
3honkz's Avatar
3honkz
I was thinking more of mid to high 900s
Old Jul 31, 2018 | 05:51 PM
C7&7's Avatar
C7&7
It’ll make over 900 or closer to 1000 with the 2.93 and the right tune. Mine made 1080-1120 depending on the conditions with the 2.93 ~22 psi.
Old Jul 31, 2018 | 05:57 PM
3honkz's Avatar
3honkz
nice numbers and thanks for the input fellas. I am just waiting for this texas 100+ degree weather to cool down to make a move and pulley this sucker down.
Old Jul 31, 2018 | 07:16 PM
black_c7's Avatar
black_c7
they can make any size you want and any number of ribs
Old Jul 31, 2018 | 10:00 PM
3honkz's Avatar
3honkz
Old Aug 6, 2018 | 09:03 PM
Ghostnotes's Avatar
Ghostnotes
Hope nobody minds if i jump in but i was getting ready to ask about my setup.
I have a V7 YSi coming with a stock diameter crank and a 3.6 upper. I am trying to keep it between 700-800 crank HP (old school) for now. My bottom end is billet forged but my clutch, tube and axles are still stock. I have a pretty radical cam already with longtubes and am going to try to mod my araid if i can, no meth yet.
Question is, should i be worried about slippage on an 8 rib and will i be close to those numbers. I was told by a questionable source that it might actually be difficult to get below 750 with that setup.
Old Aug 6, 2018 | 09:07 PM
C7&7's Avatar
C7&7
Slippage won’t be an issue, but yea it’ll make about 16-18 psi probably. That’s good for 800-850 with any timing.
Old Aug 6, 2018 | 09:08 PM
ysb02's Avatar
ysb02
With a 4" pulley, 10% OD crank pulley I got slightly over 600rwhp on a ls6 w/ long tubes. A 3.6" with a LT1/4 should be ~750. A 3.8" would be ~700-725 probably.
I don't have exp with the c7 drive but 3.6 upper / stock crank shouldn't be in the danger zone for slip at all. Once you get closer to 3" upper you probably should start to worry about it.
Old Aug 6, 2018 | 09:23 PM
Ghostnotes's Avatar
Ghostnotes
I'm just worried about breakage until i get better driveline parts. Probably end up going conservative with the timing and torque settings to pull spark for the time being if i start getting near 800..
To Ysi pulley combination and boost level
