WEAPON-X.1700 C7 Stingray 1,450 WHP - F1X, SPI Kit, Chiller and more - NO LIMITS!
St. Jude Donor '14
This build is the pinnacle of performance with every revolutionary thing we've released from our LT427 sleeved engine, Big Valve heads, Boost Freeze Chiller to our Secondary Port Injection SPI Kit, perfectly fueling this F1X 25 PSI ethanol fed beast and combined them with the best the aftermarket industry has to offer! Shawn brought his 2014 Blade Silver C7 Z51 to us with another shop's 600whp package with an ECS kit and cam and he was happy, but he loved all of the wild things we've been working on and wanted a best of the best build, and judging by his comments, I'd say he got exactly what he wanted!
“Ben - It’s incredible, totally different car! So well behaved. No issues...idles well, no stalling or hesitation, and can coast getting off the highway and it goes straight to a perfect idle. I would not have predicted you could make it this close to perfect given the radical mods we have done to the car. Damn near a 1500 hp daily driver. Thank you!!!"
I'll take you through this from starting X1500 package to finished X1700 package, so you can see the road blocks we ran into along the way with some restrictive parts. This car was a first for a lot of things, so while being first gives you the glory, it also challenges you to think ahead to prevent potential problems. I'll explain this in greater detail later, but the vastly inefficient intercooler sold in the F1X kit is a real problem for big boost and the X1700 is worlds better after the X1500 package with the development of our port injection fueling kit, which allowed us to be more aggressive than the 93/meth kit. This car has a fuel consumption like we have NEVER seen before too.
X1500 PACKAGE INCLUDES
Engine
Engine
- WEAPON-X LT 427 Sleeved Block - Wiseco 4.125 10:1 Pistons, Callies Ultra Rods, Callies Magnum 4" Stroker Crankshaft, Clevite Bearings
- WEAPON-X LT1 Big Valve Heads - PAC1209X Springs, 2.2" Ferrea Titanium Intake Valves, 1.6" Manley SS Exhaust Valves
- ARP Head Studs
- ARP Engine Studs
- Manton Pushords
- Johnson 2126 LSR Lifters
- WEAPON-X Stage 4 "ENIGMA" Camshaft - the most aggressive we've done in an LT engine!
- ATI Balancer
- American Racing 2" Headers and ORX
- WEAPON-X 160* Thermostat
- Brisk Spark Plugs
- Magnecor 85kv Spark Plug Wires
- WEAPON-X Custom Valve Covers -16 PCV System
- WEAPON-X Big Boost Catch Can Kit
- Procharger F1X, Red Race Valves - modified IC, charge pipes, etc
- WEAPON-X Griptec Stage 3 Pulley
- WEAPON-X 4.5" Intake for Street
- Procharger Bell Mouth Intake for Track
- MSD WEAPON-X Shaved/Ported Manifold with WEAPON-X Body matched Beauty Cover
- Nitrous Express - Direct Port Nitrous
- Dewitts C7 Gen 2 Radiator
- Procharger Air to Air Intercooler
- Mantic 9000 Triple Disc Clutch
- GForce 1500HP Outlaw Axles
- Kaizen Speed TR6070 M7 Trans Brace
- WEAPON-X E-Diff Spider Gear Upgrade
- RPM 4pt Roll Bar
- C7 Z06 Big Brake Kit
- Goodridge Stainless Steel Brake Lines
- FIC 194lb Injectors
- Nitrous Express Direct Port Meth
- WEAPON-X Stage 2 Low Side Fuel Kit
- ProMeth C7 Trunk Tank
- Nitrous Outlet C7 Fuel Cell
- Royal Purple 20w-50 Oil
- Amsoil Ea Oil Filter
- Amsoil Coolant Kit
- Ballenger Dual Widebands
- HP Tuners E92 PCM
- NX Max5 Controller with LCD Screen
- Lingenfelter Timing Box
- NX Dash Gauge with Nitrous Buttons
- WEAPON-X Wide Body Z06 Conversion Kit
- RKS Extractor Hood
- WEAPON-X Splitter
- WEAPON-X Rocker Blades
- WEAPON-X Spoiler
- WEAPON-X "X1500" Badges
- WEAPON-X "X1500" Floor Mats
- Forgeline GA1R 19x10, 19x13" Wheels
- Toyo R888R Tires
- ZL1 AddOns Tow Hooks
- 427 Carbon Badges
- Engine Dress Up Kit
Whats your plan going forward to address the 9psi lost through the standard IC core?
St. Jude Donor '14
X1500 Summary
As mentioned previously, the fuel consumption of this setup was incredible! We were spraying nearly 50 GPH of direct port methanol on top of the overdrive fuel pump and 194lb injectors and we STILL could not run any ethanol blend. In fact, we had to upgrade the line pump just to be able to run 93 octane! We have a Mustang 1100AWD dyno, and I'm always the first to admit it doesn't read as low as your typical Mustang; however, it does read lower than a Dyno Jet. Regardless, we could not get this setup to make the power I wanted out of it.
So, we began to troubleshoot the overall setup:
- F1X was spinning at approx 80K RPMs, having started out at 70K just to get over 1000whp.
- Timing was lower on this setup because of 93/meth as well.
- Blower speed was high creating heat; however, that much methanol kept the temps well within check.
- Meth works to supplement fuel and add cooling, but I never like the complications of it over proper port injection fueling, so that was in development in the background.
- The blower outlet pressure was 29 PSI; however after the Procharger intercooler, we were only seeing 20 PSI at the throttle body, which means we had a 9 PSI pressure drop through that intercooler!
St. Jude Donor '14
- WEAPON-X SPI Kit - amazing tank to tip port injection system with Custom Controller including AFR correction, pump, injectors, custom line lengths, plug and play harness etc!
https://weaponxmotorsports.com/produ...=5777974296603 - WEAPON-X Boost Freeze Chiller - custom complete plug and play solution
https://weaponxmotorsports.com/produ...=5777974296603 - WXM Heat Exchanger - (included in Chiller kit)
- G1Pro ATW Manifold - onsite soon!
St. Jude Donor '14
WEAPON-X ATW F1X Kit
So, the first challenge we had was clearing the hood with this massive manifold, so we did the RKS Cowl Hood and it turned out really slick on the convertible especially!
Next we had to convert the front end to the C7 Z06 baffle and fab our own charge pipe with dual Red Race Valves
St. Jude Donor '14
The most important part of this, given the C7s lack of space as well as the simplicity of pushing a button vs. running a tank, lines, pump, and extra 100lbs is the Boost Freeze Chiller kit we've been developing the last year. We have successfully hit water temps as low as 25* with the push of a button. You get more timing, less boost due to the dense air, less weight, and no hassle. This is the same system I'm running on my compound boost ZL1 making nearly 30 PSI!
Boost Freeze chiller technical data: https://weaponxmotorsports.com/blogs...th-a-15-pulley
rajahhindi (10-30-2018)
Received 1,762 Likes
ttt
Ben that has to be one hell of a ride for sure.. Very nice job on the car also... Robert
