C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LT4 blower results
Old Jan 2, 2019 | 06:43 PM
douniasg's Avatar
douniasg
Default LT4 blower results
Hey guys I finally got the car dynoed today. Car made 676rwhp and 712 torque. Car feels amazing and I am super happy with the results. Mods are lt4 blower, injectors, pump , mti low side, afe cai, 2" long tubes, 95mm tb, alkycontrol, e85 and 10% od pulley. Special thanks to Howard and Rich at Redline Motorsports for a fantastic tune.
Old Jan 2, 2019 | 11:14 PM
Fast6.3's Avatar
Fast6.3
Nice numbers
Old Jan 3, 2019 | 12:16 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
How much E did you run and how much meth were you spraying? Also, how did your low side do? Did it keep up good?
Old Jan 3, 2019 | 01:43 AM
hogurt's Avatar
hogurt
Solid results. Congrats. How much boost are you running.
Old Jan 3, 2019 | 09:14 AM
douniasg's Avatar
douniasg
I have a single nozzle I believe it's a 15. Car is running 100% pump e85 content was e76. From what I understood the low side was keeping up good but high side was dropping off and couldn't keep up without meth. The car made 11 lbs of boost. I think the fuel is pretty much maxed out without more meth or cam.
Old Jan 3, 2019 | 10:05 AM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
Thanks for using for you fueling needs. We love hearing feed back from you guys!!!
Thanks,
Billy
Old Jan 3, 2019 | 11:04 AM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
Congrats. Stock or ported blower?
Old Jan 3, 2019 | 11:09 AM
Redline Motorsports's Avatar
Redline Motorsports
The low side hung in pretty good until the end. 100% E85 is quite taxing and we don't typically recommend it. The meth was able to recover what was getting close to being short. Good results, fun car! Enjoy it and thanks for your support!
Old Jan 3, 2019 | 11:55 AM
snak's Avatar
snak
2nd Gear
Default forged pistons
Thanks,
Billy
y write that going over 600 whp will need forged pitons,so what do y think about this build?
Old Jan 3, 2019 | 12:06 PM
douniasg's Avatar
douniasg
Thanks, stock blower but I port matched the throttle body opening for the 95mm tb.
Old Jan 3, 2019 | 12:18 PM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
Because we have seen quite a few of them break the lower ring lands. I like the build a lot. If it was a build in the shop I would have to warn the customer what could happen.
Old Jan 3, 2019 | 01:06 PM
snak's Avatar
snak
2nd Gear
Default rods
what about forged rods?do y have to change them too?
Old Jan 3, 2019 | 05:21 PM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
The rods IMO are good to 850 no problem.
Old Jan 3, 2019 | 08:43 PM
hogurt's Avatar
hogurt
Yep. You need the cam to increase the fuel lobe. That would also be a good time to add your forged pistons.
Really impressive results. Now you are gonna need some new shoes to keep the car from spinning on every pedal smash.
Old Jan 4, 2019 | 09:15 AM
douniasg's Avatar
douniasg
Originally Posted by hogurt
Yep. You need the cam to increase the fuel lobe. Thst would also be a good time to add your forged pistons.
Really impressive results. Now you are gonna need some new shoes ro keep the csr from spinning on every pedal smash.
haha you are so right. I am curently looking for some 18s for drag radials.
Old Jan 13, 2019 | 12:02 PM
MrGary2011's Avatar
MrGary2011
I am right at 600rwp and won't push higher unless internals are swapped out (Course I say that but the SC is ported out to 103 mm sacrilege not to get a bigger throttle body -heheheeee). Extremely happy and confident the engine will hold up. Fun stuff!
Old Jan 13, 2019 | 11:34 PM
hogurt's Avatar
hogurt
That is right at the limit for 93octane on the Lt1 fuel system. Did you upgrade the fuel system or are you adding alky?
To LT4 blower results
Old Jan 14, 2019 | 06:51 AM
MrGary2011's Avatar
MrGary2011
That is right st the limit for 93octane on the Lt1 fuel system. Did you upgrade the fuel system or are you adding alky?
I put the LT4 fuel pump in, LT4 injectors and brisk spark plugs (and Corsa X pipe)
Old Jan 14, 2019 | 07:54 AM
hogurt's Avatar
hogurt
LT4 high pressure fuel pump or in-tank pump for the low side?
Old Jan 14, 2019 | 08:12 AM
MrGary2011's Avatar
MrGary2011
LT4 High pressure fuel pump!
