C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LT1 Nitrous & e85
Old Feb 10, 2019 | 02:00 PM
graysilv's Avatar
graysilv
Default LT1 Nitrous & e85
I have a 2015 z51 A8, and planning on installing the following:
1 7/8 LT headers and xpipe
e85 flex fuel sensor
100 shot of nitrouse
afe cold air intake
Tune
If I run straight e85 and 100 shot of nitrous will the stock fuel system on the LT1 be able to handle it? If i recall someone mentioned I might have to upgrade my fuel pump. Any info and or advice will be greatly appreciated.
Old Feb 10, 2019 | 04:35 PM
C7&7's Avatar
C7&7
Nope. Stock fuel system doesn't stand a chance. You will need a AUX low side and LT4 injectors and high pressure pump. The e85 variable is where you fall short.
You could do a 100 shot on the stock fuel system, but not with e85 also.
Old Feb 10, 2019 | 06:39 PM
3honkz's Avatar
3honkz
With that setup u can do 100 shot with e85 with no problem with stock fuel system. I did it for years before adding a cam. E85 is actually safer to run with nitrous. The need to upgrade fuel system is when ur boosted and making over 650-700whp and wanting to run E85. Hell I made 750whp on 93 and meth boosted on stock fuel system
Old Feb 10, 2019 | 09:23 PM
GeorgeR_Zed06's Avatar
GeorgeR_Zed06
I ran nitrous on my old Z and instead of upgrading the fuel system, I just went with a standalone tank and filled it with MS 109. Worked flawlessly!!
Old Feb 11, 2019 | 05:39 AM
zuritausmc's Avatar
zuritausmc
Veteran: Marine Corps
Yea I'm on straight e85 now na and my tuner told me no way after looking at the duty cycles. He said best bet was to run a fuel cell with c16 for the nitrous. The nx fuel cell is about $500 unless you go with the version you can use with boost which is a few hundred extra.
Old Feb 11, 2019 | 10:42 AM
C7&7's Avatar
C7&7
Yea the stand alone fuel cell is the solution for you. that takes the burden off the stock fuel system when on the spray.
Old Feb 11, 2019 | 11:41 AM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
We sell a AUX low side fuel system.
https://mti.store/products/copy-of-a...sport-corvette
Old Feb 11, 2019 | 11:18 PM
98TransAm's Avatar
98TransAm
Youll be fine on stock fuel system and e85 on a 100 jet. 150 maybe but 200 definitely not
Old Feb 12, 2019 | 01:51 PM
Danengraham's Avatar
Danengraham
I asked this same thing a while back. 500-550 rwhp is about all that is safe on E85 on the stock fuel system. Just how far you want to push it is up to you and your tuner, could do a 75shot to play safe. Or get LT4 injectors and pump would be the correct fix. Also could possibly do a E30-E40 mix, but that seems like a hassle to me.
Old Aug 6, 2020 | 12:33 PM
C3_ERROR's Avatar
C3_ERROR
If you have a wet sump motor the C6 stand alone fuel cell fits perfect in the C7 passenger fender. Check out this members post. I talked to him and he said he only has to make a lower bracket for it if I remember right. I wouldn't run a 200 shot on the stock fuel system. It might work but for the extra money I would feel more comfortable with a stand alone.
Here is the fuel cell he used. I mean what is the ZL1 pump going to cost you?
https://nitrousoutlet.com/i-30559879...el-system.html
https://www.corvetteforum.com/forums...and-alone.html
To LT1 Nitrous & e85
