C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Adding TVS2300 Heartbeat
Old Mar 16, 2019 | 11:41 PM
TSLAVette's Avatar
TSLAVette
Default Adding TVS2300 Heartbeat
To GS LT1 A8. Using Magnuson tune to keep warranty. What kind of 0-60 improvement could I expect? Quarter mile times?
Thanks guys. Any other suggestions? BMS filter, Range AFM and Vitesse throttle controller are only additions. SC goes on in April.
Old Mar 17, 2019 | 08:26 AM
hogurt's Avatar
hogurt
High 10’s in the low 130’s. Assuming you have traction.
Old Mar 19, 2019 | 12:57 PM
samwint77's Avatar
samwint77
I had a gs a8 with a maggy. low end torque was immediate. 1st gear was useless with the stock cup 2's (my car had the z07 package). When it did grip it was very quick. I had the 95mm pulley, but also had long tube headers and x pipe w/o cats and a custom tune. Just be carefull with it. take you time to get used to the power.
Old Mar 19, 2019 | 11:49 PM
Scudz's Avatar
Scudz
Can someone explain all this tire spinning in first gear? Are you turning traction control off or is this happening with TC on?
Old Mar 20, 2019 | 08:51 AM
samwint77's Avatar
samwint77
With it off. With it on you just can't put the pedal all the way down. I had stock tires as well. My z has non run flats and it makes a big difference.
Old Mar 23, 2019 | 07:24 PM
GT2BHPPY's Avatar
GT2BHPPY
Read somewhere that the tune from the S/C removes your launch control. Truth or rumor?
Old Mar 24, 2019 | 03:38 PM
spinkick's Avatar
spinkick
What kind of tires? I was thinking about r888's
To Adding TVS2300 Heartbeat
