AA Kit: Why so much blow by through the blow off valve
OK I am sure someone is going to say "because that's what the blow off valve does" or some chit like that, but damn I have switched from the SI unit and the big bubba to a Ti headunit and the race port, and it is the same chit. Today I drove it rather hard and at one point I had blow off coming through the sie vents of my aftermarket hood. There is oil mist everywhere in the Blow off area. I assume this is normal?
How much oil?
Do you have a catch can setup installed?
Received 1,762 Likes
Ttt
Buddy I have a TI set up dont have any blow by but also have a MM catch can also. But just put a fully forged parts on the inside & next week should be tuned hoping for about 850 rwhp with all the parts that went in her. We will see on the blow by then... Robert
Virgil6868 (06-08-2019)
I agree the c7 was so bad due to piston rings being so close the non z06 ring gap is like 8,k and the z06 down to 16,k most builders will gap at 20,k to 25,k all on the rwhp set up on the motor. Robert
Sorry man but that is a pretty stupid assumption. Not only is my car tuned but when I went from the Si to the Ti I had it retuned and it is spot on. I think I probably hurt the motor. When I first had the car tuned I had a habit of revving it out all the time so I could hear it blow off. LOL Sounds like I hurt it. Its not an issue if I drive it normal or go in boost at times, its when I am beating on it. Looks like forged internals for me. Woohoo
Cruise-In IV Veteran
Went back and looked at my response and it was kind of a d!ck move. I appreciate everyones feedback. I am really not worried about it. I am going to add the MM catchcan I ordered and go from there. When I am bored I will then do the compression test and obviously at the same time check plugs. Car runs great and made 655RWHP on a conservative tune.
The MMS can is plenty and that's what most run.
Driver side shot
Passenger side shot
MMS overflow to AMP tank (custom banjo fitting to Fragola -10AN lines/fittings)
Oil/Sidekick lines to passenger valve cover (katech valve covers)
Just literally had this happen to my car. Same head unit and bov. I am not running a catch can so I guess I need to start there but man am I concerned! I just picked the car up three weeks ago from install and this is only the third time to do a hard pull on it and I have oil everywhere def more than the mist some have mentioned. Car ran fine under normal driving though. Oil pressure is fine. Hopefully just needs a catch can!
Former Vendor
My car has the same issue. I have a catch can and I get oil everywhere, it blows out the filter on the catch can and is all over the underside of the hood. I thought maybe my guys filled the oil up too much on the last oil change or didn’t drain the catch can. I had them leave the oil low a bit and empty the catch can. Needless to say it didn’t help. I’ve been driving it that way for a bit, but I just haven’t been getting on it, if I do I get oil everywhere. I’m close to getting it built anyway, so once I do I’ll have them diagnose it and let me know what happened.
I am with you and am going to just have the engine tore into and built but what sucks is I literally just had this work done! Makes me not even want to drive the car at all! Quite annoying to be honest and just pisses me off thinking about it!
I am am going to get the original builder/tuner to go through it and just see what he thinks but I am assuming the worst.
Supporting Vendor
i have seen more than one 14/15 with what i would call unusually high blowby
this can put extra load on the vent system, and without a catch can you are sending this now oily air into the front of your s/c, then through the intercooler, then onto /into the engine and sometimes of course out the bypass valve when it opens.
i have also seen more than one lt1 car that has broken piston(s) acting the same way.
related to my product please don't hesitate to email me if anything seems like it is functioning abnomally and I can walk you through some simple tests to make sure at least the catch can is healthy.
