1-7/8 versus 2" headers. Is there that much of a difference?
Looking at upgrading headers soon, is there much of a difference in 1 7/8's versus 2". Looking at Kook's or ARH. Currently making 764/814 with off road pipes but a cam and the 2650 is in for the next round of mods.
Dude the cost is basically the same, why not get the biggest ones when you know you’ll be way over 800 rw..
I did the 2” Kooks this time... vs the 2” ARH on the C5Z, and the Kooks are much nicer and the stainless turns gold... not all brown and spotty looking like the ARH did.
I bet the change is <25HP.
Throw the blower on the 1 7/8" headers and see where you land. Then you can make the decision to upgrade.
Then you can communicate to the rest of us the dyno differences!
Supporting Vendor
Anything forced induction I would run 2" all the way. No questions asked. If you need a set give us a call @ 610-628-1563!
__________________
www.cspracing.com * Complete Street Performance * CALL US 610-628-1563
And don't forget to Like us on Facebook and follow us on Instagram @completestreet
Cruise-In IV Veteran
You want 2” long tubes for higher output forced induction builds. Period. It’s not even strictly about power it’s about efficiency. Engine being a big air pump especially with forced induction you want proper scavenging and flow for increased output. It matters.
Received 1,762 Likes
ttt
I again less pressure less LBS of boost on the motor with the 2 inch headers. In turn you can turn it up a little more & make more power at the same boost level.. Robert
Yes I would run 2 inch over 1 7/8's no reason not to on a boosted car . Bigger difference with the 1 3/4. A few guys still run them but those are too small for me to use.
Just not a fan of how close the 2" get to plugs, starter, oil lines etc,
I honestly may just cheap out and get 1 7/8's and put the money towards the diff when it brakes.
Cars been moving with just the off road pipes (9.55@143) and I recently tested a car with AR 2" over the Off road pipes and there as no difference.
https://youtu.be/4kMwUNGSyaQ
Have seen them back to back on dyno's.
1 7/8's are fine for stock boost levels on Z06's and way plenty for NA LT1's. Unless you are cranking up the boost, there isn't an advantage by going 2 inch. But at the same time, there isn't a negative side by going 2 inch either.
I don't know about that. Put a Procharger on an other wise bolt on Z06 with off road pipes and swapped to 2" AR's and it made 0 difference. 780 rwhp on the stock cam.
Received 2,380 Likes
I run ARH 1 3/4 mid lengths with a Whipple 2.9, lol. I would expect no appreciable difference going to 2" long tubes and I am definitely not chopping up my Akrapovic to find out.
You will never sell that to me! I don't think that's true it sounds off from what I have seen on the dyno while they are being tuned 2 inch headers make more power than just cat delete pipes everytime . Way rather have 2 headers on my car you guys can run cat deletes all day long if you want. They produce not as good of sound either
https://youtu.be/O1bXPNy1Yn4 According to this 1 3/4 headers leaves a LOT on the table to 2 inch even at 600 hp..
If it will run a 9.50 now and 9.35-9.40 on 2" headers that might rub and require hacking up an 8k dollar exhaust system, should I worry about switching?
Maybe if I was worried about heads up racing at the track on a regular basis for money, points, and glory it might make sense, but then, I would have used a different car anyways.
This is what I had to do on my AKRAPOVIC X pipe had to cut the pipe up at the header, But even more had to put a belt like around to two pipe up front then pull them into together, Had to have a piece of this stuff tig welded the to pipes closer together cost me 450.00 for a small piece & to have it tig to two pipes closer together so the X pipe would flow together with the LT headers . Then put the bands from the headers to the X pipe LOOKS good but the time & 450.00 cost... Robert
ajrothm (10-14-2019)
