C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Recommend meth kit
Old Oct 18, 2019 | 03:24 PM
BlueDevilZ51's Avatar
BlueDevilZ51
Default Recommend meth kit
I’m getting timing pulled on my Edelbrock E force on long pulls due to IATs 140*+. I just want to look into a meth kit that will work on my blower just for cooling not fueling. I heard some kits use the windshield washer tank. Thanks
Old Oct 18, 2019 | 05:07 PM
Corvette4ever's Avatar
Corvette4ever
I tried water injection with my Magnuson, didn't seem to lower IAT that much. Took it off and sold it
Old Oct 18, 2019 | 05:11 PM
BlueDevilZ51
Did you log to see if the water injection lowered the IATs or not? Did you try it with meth or 50/50?
Old Oct 19, 2019 | 01:41 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
Alky meth kit seems to be the most popular, I use mine for fueling though
Old Oct 19, 2019 | 11:03 AM
Corvette4ever
I used 100% water instead of 50/50, as water is supposed to be more effective than meth for cooling the intake charge. Unfortunately for a PD blower this had minimal effect, I did log IAT temps via HP Tuner scan and saw only a 7-10F lower temp during a 10sec WOT pull
Old Oct 19, 2019 | 11:39 AM
BlueDevilZ51
Ive always heard meth would have cool better then water does. 7-10 isn’t bad for just water. I’m looking for around 15* of cooling so a 50/50 mix might really help me.
Old Oct 21, 2019 | 11:53 AM
us3rname's Avatar
us3rname
PD blower with alky m10 spaying 100% methanol got my temps down from the 150's to the 130's during 2-4 gear pulls. I also have my nozzle pointing straight at the TB and not down at the intake piping.
Old Oct 21, 2019 | 12:36 PM
robert miller's Avatar
robert miller
I agree on the 100% pure meth but I am using two 10,s direct into the T.B. Robert
Old Oct 21, 2019 | 12:42 PM
us3rname's Avatar
us3rname
How much are you boosting? I moved it up to a single m15 and it loved it. Id like to try duals but with the odd mix of nozzles I have I am limited to 25 and 30lph combinations.
Old Oct 21, 2019 | 02:31 PM
Dane@LGmotorsports's Avatar
Dane@LGmotorsports
Premium Supporting Vendor
We use Alky Control 100% Meth
Old Oct 21, 2019 | 02:59 PM
pj-c7's Avatar
pj-c7
Magnuson and Alky Control 70/30 Meth/water for two years now. I had read that you should use 100% when spraying through a PD blower but,
I didn't want to lose the affects of the water cooling, and at same time, keep the mix a bit safer to handle. Just my limited experience thoughts. YMMV and all that...
I also noticed that adding a high flow air filter helped keep IATs down a little longer...
I was noticing during a dyno pull that even with the meth setup, the IATs would eventually start to climb again at the very end of the pull.
Adding a high-flow air filter helped reach the end of the dyno pull without IATs climbing up again.
In case it helps anyone.
Pj
Old Oct 24, 2019 | 01:10 AM
GeorgeR_Zed06's Avatar
GeorgeR_Zed06
Water injection isn't really used to cool the air charge (although, it does a little), it is used to cool the combustion chamber so you don't scatter piston tops. It really does work when direct-injected into the CC. We used a lot of it on big nitrous cars.
Old Oct 26, 2019 | 04:51 PM
chefcg1's Avatar
chefcg1
C7 of Year Finalist (performance mods) 2019
I’m using 2 nozzles 10 and 15. In past builds I always used 50/50 mix, but now at 100% meth on the vette since I’m using it for fueling at 640whp to be safe and don’t have hptuners to really log like I did with other builds.
Old Nov 2, 2019 | 05:51 PM
robert miller
I agree no way that 100% water will do better than meth I use 100% meth. Also here OP the above kit is the only way to go on this.. Robert
To Recommend meth kit
