C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Blower options
Old Nov 12, 2019 | 01:15 PM
c7will's Avatar
c7will
8th Gear
Default Blower options
Currently have an LT4 block (no blower) heads/cam (32% fuel lobe) with kooks headers & X pipe. I’ve been looking at many options as far as forced induction goes (P1, D1, F1 procharger, ysi, etc). Not entirely sure what my best option would be. Plan to max out stock LT4 fuel system (750 whp I assume on full e85) then in the future add meth to the mix & make 900-1000 whp. Read tons of threads about certain blowers being spun inefficiently or too hard & also people saying that certain blowers are sluggish in the power range. Looking for a blower that can suit my goals if possible while also being stout throughout the power range...
Old Nov 12, 2019 | 01:40 PM
BooSSted's Avatar
BooSSted
Is your goal just dyno numbers or will the car be used in a certain fashion? You state you have a cam already, is it ground for a PD blower or Centri blower? Depening on that and if you'd want to possibly "redo" your cam that may steer you towards a product.
That said and depening on how you plan to use the car I'd be looking at the F1 series blowers or the 2650 for you end goals. With the 2650 probably being your best option. And you should get your fueling situation figured out and done before doing power adders IMO. Theres plenty of great solutions now available.
Old Nov 12, 2019 | 07:07 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
Consider a ported OEM blower, Maggie 2300 or 2650
Old Nov 20, 2019 | 04:01 PM
c7will's Avatar
c7will
8th Gear
It’s ground for both a PD or a Centri blower to my knowledge....it’s made for boost. Also not just looking for dyno numbers...car will be ran on the street & track. Performance>dyno numbers. Planning on getting the LT4 hpfp + injectors along with a meth kit & a low side soon.
To Blower options
