C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E85
Old Nov 22, 2019 | 06:49 AM
BlueDevilZ51's Avatar
BlueDevilZ51
Default E85
I have an E force Stingray and was thinking of doing the HPFP and Zo6 injectors as well as the low side. I was curious if I did those mods would I have enough fueling to support E85?
Old Nov 23, 2019 | 08:47 AM
C7&7's Avatar
C7&7
Full e85 no. Not without meth.
Old Nov 23, 2019 | 10:17 AM
CamOnlyJabroni's Avatar
CamOnlyJabroni
A flex fuel sensor is a good option to mix some e content into the car and get most of the benefits from running full e85. Without taxing the fuel system completely.
Old Nov 23, 2019 | 10:19 AM
douniasg's Avatar
douniasg
I have all those fuel mods and single nozzle meth made 680 rwhp on e85. Definently need meth. My fuel system is maxed out unless I do a cam.
Old Nov 27, 2019 | 12:14 AM
hogurt's Avatar
hogurt
on my Camaro, I added the LT4 hpfp and injectors along with the ZL1 low side pump. I also added a voltage booster. On the motor, I added a cam with a larger fuel lobe. I run straight e85 from the pump with no mixing.
For testing, I ran boost at 7, 10, 12, 15psi. In the last setting the injectors tapped. My intent was to switch from e85 to race fuel for the track, but never got around to it. Through the a8 at those boost levels I went from 700whp-800whp.
Since then I dropped to 10psi and will drop back to 7psi tomorrow. It’s just no fun when I can never smash the go pedal.
I am about to have the exact same setup on my Vette. The only difference is, I am not planning the voltage booster and not upgrading the in-tank pump. I figure the Vette will probably run closer to 650whp. I just don’t know where the stock Vette in-tank pump will tap out. I may add the DSX system for safety and then if I want to up the boost I can.
To E85
