C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Which boost gauge?
Old Dec 18, 2019 | 09:00 PM
furious427's Avatar
furious427
Default Which boost gauge?
Hey Guys, for those of you with superchargers on your C7's, which boost gauges are you using? I am in the process of installing a pro charger kit and I wanna keep an eye on boost. Are there any new ideas out there verses the big old ugly gauges?
Old Dec 18, 2019 | 09:13 PM
Habeas Corpus's Avatar
Habeas Corpus
I’ve been researching myself and probably going with NGauge. It’s expensive as hell but it has everything. Compatible with HPTuners and saves data logs and tunes
Old Dec 18, 2019 | 09:28 PM
furious427's Avatar
furious427
See I kind of want something were I don't have to drill any holes to mount, something simple.
Old Dec 19, 2019 | 07:02 AM
furious427's Avatar
furious427
I am really considering this....
http://www.p3cars.com/chevrolet/p3-v...uge-2014-2019/
Old Dec 19, 2019 | 05:56 PM
Mark Roach's Avatar
Mark Roach
3rd Gear
Go with the nGauge if the boost pressure is piped into the OBD2 system. It's suction mount and will give you every parameter you could want. Up to 6 gauges (out of hundreds) can be displayed at once. Boost and IAT are good to watch. Knock is another.
Old Dec 19, 2019 | 09:34 PM
Silverboost's Avatar
Silverboost
Dashlogic is pretty trick also
Old Dec 21, 2019 | 08:15 AM
DorkMissile's Avatar
DorkMissile
Navigator
Believe it or not, but the Banks (yes, the diesel people), make a great OBD gauge that can read boost (not just MAP) AND can read an added Ethanol sensor. I bought one in August and it works great.
https://www.bankspower.com/series-2-...per-gauge.html
Old Dec 21, 2019 | 11:23 AM
ajrothm's Avatar
ajrothm
That Banks unit is pretty trick!
Banks has always made good stuff.
Old Dec 28, 2019 | 09:58 AM
Zane Murcer's Avatar
Zane Murcer
5th Gear
I have a P3 with the analog boost gauge hookup and love it
Old Feb 26, 2020 | 11:20 AM
jstewart's Avatar
jstewart
I use the NGauge and mounted it flush in the cubby behind the display. Works great and is fully functional with HP Tuners.
Old May 29, 2020 | 12:44 AM
Fast6.3's Avatar
Fast6.3
can you post a picture how did you run the cable
To Which boost gauge?
