C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Removing IC Bricks
Old Jan 18, 2020 | 03:46 PM
ZL1427MH's Avatar
ZL1427MH
Default Removing IC Bricks
Attempting to prep my SC, for shipment and want to remove the 2 IC Bricks.
After removing the 3 Allen head bolts. How do I safely remove the Bricks ?
I don't want to damage them. Any help would be appreciated.
Thanks Marc
Old Jan 18, 2020 | 04:41 PM
ssmith512's Avatar
ssmith512
Pull them up from the rear and once they are just high enough to pull them rearward, pull them rearward. There are a tiny bit stiff from the o-rings, but will pop out fairly easily.
Install in reverse, apply a little lube to the o-rings to help them slide into place.
Old Jan 18, 2020 | 04:55 PM
ZL1427MH's Avatar
ZL1427MH
Thank You, Sir.
To Removing IC Bricks
