C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
TVS2300 Confusion
Old May 14, 2020 | 06:17 PM
Hate2Wait's Avatar
Hate2Wait
Default TVS2300 Confusion
So I have been reading several threads on here about some basic bolt on's and adding the 2300, but only getting to 660-680whp. That seems really low to me for replacing the supercharger. If just the s/c change is good for ~90whp and most LT4's are getting 575 to the wheels that would be 670 before intake/tb/headers/ actual tune. Leaves me wondering if it is a tuner issue, or a car issue. We all know that the LT4 needs cooling, and fuel modifications to make moderate/high WHP goals. With that being said is it possible to get 720+ before getting into the engine? What becomes the weak point, is it the low side?
My car made 661/709 at the time of original tunning, and went to 647/706 10k miles later on a mobile dyno. I would say that it is a 655whp car. This is with TRIC halltech intake, 15%od pulley, ported tb, headers/x/ overaxle exhaust. If I were to add the TVS2300 could I expect to hit 720+ on pump 93? Would adding Cordes Low side help boost that number or is next step going to be Cam/Heads? I am trying to avoid a cam as right now other than being loud at start up nobody can tell that it isn't stock. Which is my goal to have a "sleeper" (if there is such a think with the Z06) that can hold its own on the street.
TIA.
Also, what is a stock 1750 supercharger selling for now, $1200?
Old May 15, 2020 | 09:59 AM
BlueDevilZ51's Avatar
BlueDevilZ51
From what I’ve seen most stock LT4s make around 530whp
Old May 15, 2020 | 10:59 AM
KGrant's Avatar
KGrant
Wow, that seems low considering a C7 Z06 is suppose to make 650/650, if so, why do you say that "most stock LT4s only make around 530whp"?.... I have no expertise and it seems odd that a Stingray LT1 with a SC range is around 530-575+/- as I don't think that would be near a LT4 Z06 at stock is 650/650 even though I have seen dynos with lower numbers and don't understand the performance science I would think a stock Z06 still kills a stock Stingray with a standard bolt-on SC?
Old May 15, 2020 | 11:17 AM
7LitreC5's Avatar
7LitreC5
I haven't installed the 2300 on my Z06 yet but do have one on my 17 ZL1. On that car the 2300 with supplied 80mm pulley, a CAI, and 103mm throttle body made 664 on 91 and 714 on E85 (actually 66% E).
Old May 15, 2020 | 09:35 PM
BlueDevilZ51
The Z06 makes 650/650 at the crank not the rear wheels. so the general rule is subtracting 15/18% from crank HP go get whp. 650-18%= 533whp on an auto, 650-15%= 552whp on a manual. These number can vary depending on the dyno etc.
Many standard bolt on Stingrays with a SC run different amounts of boost so hard to compare that to a stock Zo6. Some stock Stingrays with just a SC will crush a Zo6 other will have very similar power to the Zo6.
Old May 16, 2020 | 03:00 PM
Habeas Corpus's Avatar
Habeas Corpus
I was at 690 rwhp and tapped out if fuel at this stage. I’ve seen some folks just over 700 on 93 pump. The 2300 is far superior blower and you can take it to the next level with low side and cam. Stock 1.7 is a hair blower and will eventually pull timing. The 1.7 will peter out quicker on top end compared to the bigger 2300 which pulls like a rape ape!
Old May 17, 2020 | 11:54 AM
99vetteran's Avatar
99vetteran
I would spend the extra grand and do the 2650. Lower intake temps and you'll make plenty of power on less boost then the 2300 Maggie. Been there.
Old May 20, 2020 | 11:05 AM
Hate2Wait's Avatar
Hate2Wait
Ive had the 2300 for a while but just never got it installed. I think I paid something around 3300 for it used. Which it is currently at superchargers online getting a once over. So hopefully it was a good investment.
Old May 28, 2020 | 08:02 AM
99vetteran's Avatar
99vetteran
Cool, Brian will take good care of it and make sure it comes back ready to rocket.
Old May 28, 2020 | 06:25 PM
black/silvervette's Avatar
black/silvervette
Well, my 2015 zo6 has the 2300 Maggie with smaller pulley, 103 snout. throttle body , afe cold air, plugs, with tune only made 651 rwhp and 651 trq.with a low side fuel. The car definitly faster, but I was hoping for a larger dyno number( no headers). Fuel is definitely the issue. I think with the 2650 you would need to estimate more money for upgrading the fuel system.
Old May 28, 2020 | 07:59 PM
99vetteran's Avatar
99vetteran
If that's on 93 octane its not that bad if you still have the stock cam and no headers. The 2650 would probably gain you another 60 rwhp or more and you'd have much lower IATs which allows you to run lower boost and probably some more timing. I went from 770 to 847 on the initial dyno running less boost. Generally once you pass 140 IAT's if its set up correctly by your tuner it will start pulling timing. My 2650 was running about 110-115 IATs going thru the traps compared to the 2300 which was 150 plus depending on how hot it was at the track and never had any knock or pulled any timing with the 2650. You might consider adding a Meth/water kit since you live in a very hot climate. I should mention that was on Vp MS109 and a Aem Meth/water kit w/1000 Nozzle.
Old May 28, 2020 | 11:43 PM
orrwhat's Avatar
orrwhat
How much boost was the 2300 vs 2650? I know the 2650 can easily run more boost and still be much cooler.
Old May 29, 2020 | 08:13 AM
99vetteran's Avatar
99vetteran
I ran 16 psi on the 2300 but when I switched to the 2650 it made 80 rwhp more on 13 psi. I never had it back on the dyno after I went to 16 psi on a smaller 75mm pulley so I'm guessing it was making 875 or so on 16 psi.
Old May 10, 2021 | 11:21 PM
twofast19@yahoo.com's Avatar
twofast19@yahoo.com
did you have a lower pulley also on the 2300 setup at 16 psi?
Old May 11, 2021 | 08:03 AM
99vetteran's Avatar
99vetteran
No I had the stock lower and a 70 mm Griptec pulley. Sometimes it was higher then 16, we would see 18 psi on occasion on the dyno and in logging at the track. I had stock exhaust is one reason we saw higher numbers.
Old May 11, 2021 | 08:36 AM
twofast19@yahoo.com
That makes sense. Thanks.
Old May 13, 2021 | 02:11 PM
twofast19@yahoo.com
I got my Magnuson TVS2300 making 18 psi now with 18% lower 3" upper full headers, and all the other goodies. Making power now, amazing what proper tuning does!
To TVS2300 Confusion
Old May 13, 2021 | 09:02 PM
orrwhat's Avatar
orrwhat
What kind of fuel system do you have? Im curious since I am getting tuned with 18 lower and 2.70 upper on my 2300 after doing a cam swap.
I was shooting for 15.5 ish psi but really dont want 18 unless fueling keeps up I suppose.
Old May 13, 2021 | 10:23 PM
twofast19@yahoo.com
I also did cam with 38% lobe fully ported heads, xdi 30% injectors, lpe high pressure pump, dsx lowside, I'm at 5.1ms. At full pull 80psi lowside. Trying e85 next...
With m1 meth dual -10 almost forgot that.
Old May 13, 2021 | 10:29 PM
twofast19@yahoo.com
wen the tune was off I was at 15 psi and felt really slow. Above that you can hear the 2300 start to finally wind up. Wen you hear the blower wine real hard you known it's working lol.
