C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Msd intake with boost
Old Jun 19, 2020 | 04:40 PM
black_c7's Avatar
black_c7
Default Msd intake with boost
Hey guys
anyone running msd intake with a lot of boost? 20psi +
how does it hold and any problem you guys had ?
Old Jun 25, 2020 | 05:32 PM
KemahGT's Avatar
KemahGT
I’ve been unable to get an answer for the same question. MSD won’t even tell you...if they even know. With a boosted application I don’t even think you would see a cost effective benefit with the change over the factory piece.
My goal is to keep turning up the boost until the factory manifold fails. Then I’ll start looking at other manifolds. If the factory one fails at a pretty high level I’d probably think about a good sheet metal intake rather than the MSD.
Old Jun 26, 2020 | 12:41 PM
black_c7's Avatar
black_c7
I have been told that msd will take up to 30psi but any hiccups or backfire it will explode.
Old Jun 26, 2020 | 01:03 PM
douniasg's Avatar
douniasg
Yup, I had one on my c5 and one backfire all the threaded inserts blew out. Turned into garbage.
Old Jun 26, 2020 | 03:10 PM
C3_ERROR's Avatar
C3_ERROR
I'm using the MSD with my Procharger but have a ProCharger intake in the garage for just this very reason. My plan is to upgrade my head unit and I don't want to take the chance.
Old Jun 26, 2020 | 08:07 PM
black_c7's Avatar
black_c7
don’t trust sheetmetal i don’t believe they will be better than the msd.
if you going for more than 25psi just go to a billet one.
Old Jun 26, 2020 | 08:33 PM
C3_ERROR's Avatar
C3_ERROR
I trust sheet metal more that composite ones. I've seen composite intake blow apart under boost.
I'm only planning around 20psi and while the msd might have held up I didn't want to take the chance.
Old Jul 25, 2020 | 05:24 PM
robert miller's Avatar
robert miller
Default ttt
The MSD was good in the c5 was at 27 lbs of boost in it never a problem at all. Robert
Old Jul 26, 2020 | 12:32 PM
JUICED1's Avatar
0JUICED1
Former Vendor
The biggest issue we have is that the MSD sits very low and we can't use the oil gallery off the valley cover. This is the feed we generally use for turbos or non self contained centrifugal blowers. We've had a few in the 15 psi range with no issues so far.
Old Aug 7, 2020 | 02:18 PM
Hoboshop's Avatar
Hoboshop
yes you can I have a mamo ported msd and a ysi with a lme 416 and cid Max heads on my c7. It feeds oil right from the valley and drains to the pan.
Old Aug 10, 2020 | 12:12 AM
JUICED1's Avatar
0JUICED1
Former Vendor
What fitting did you use? We couldn't find anything that would clear it.
To Msd intake with boost
