Im trying to figure out what WHP i should be around.
The new build includes
GPI pistons/Rods
Vengance racing Stage 3 Cam 32% lobe
LT4 Injectors/Pump
DOD Delete
MTI lower Aux pump
Kong Ported blower
Katech 105 TB
NX lid with Direct port Meth 50/50
Kooks headers /X Pipe Borla Exhasut
5 inch Corders intake
15% ATI lower
2.4 upper
What do you guys think? and how much E85 do you think i'll be able to run?
It depends on who's tuning it but generally speaking you can't run much over 700rwhp. Running straight E85 is really tough on these motors. Meth and 100 octane are your friends.
Your ethanol content will be directly related to how much meth you run. The more meth you run the more load you take off your fuel system.
Most I've seen done by rpm was 850 whp / 897 wtq and cpr was 842 whp/ and I forget the wtq. I have close to what you have. My dyno pull was was no meth cause I still need to buy it. In 5th with sae correction factor netted 671 / 751 on pump 93.
I'd think with e50 and 100% methyou should see over 800 wheel
thats pretty impressive. It was around 660 whp. Only additional power adders really is the stage 3 cam, lower, and 5 inch intake.
and the pistons and rods for safety.
did you change out the crank bearings? The thrust bearing is the weak point.it goes before the rods.
I have 5" cordes, zr1 modified 100 soler TB, kong port job, 1 7/8 lt headers, 3" off road x, 13% lower, 2.3 upper, mti custom cam with 32% fuel lobe, jms fuel pump booster, and flex that I cant use lol
GPI pistons/Rods
LT4 Injectors/Pump
DOD Delete
MTI lower Aux pump
Kong Ported blower
Katech 105 TB
15% ATI lower
2.4 upper
