C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fueling
Old Dec 20, 2020 | 06:03 PM
C6zred's Avatar
C6zred
Cruising
Default Fueling
2015 stingray——Would it be feasible to make 750-780ish on an aux low side kit, LT4 HPFP, and a cam with larger fuel lobe?
car currently makes 650 on a vortech blower (9.5 lbs boost), and full exhaust with methanol injection.
Aiming to use the meth only for cooling, so I need to know what I may need fuel wise.
thanks in advance!
Old Dec 21, 2020 | 03:05 AM
16 Stingray's Avatar
16 Stingray
Injectors?
Old Dec 21, 2020 | 09:51 AM
C6zred's Avatar
C6zred
Cruising
Originally Posted by 16 Stingray
Injectors?
LT4 type
Old Dec 21, 2020 | 12:15 PM
C7&7's Avatar
C7&7
Not without more meth to help with injector timing. It will dependent on meth not just a cooling agent. Do the better high side injectors and you can remove meth at this power level.
Old Dec 21, 2020 | 03:11 PM
C6zred's Avatar
C6zred
Cruising
can you define better injectors for me?
Please clarify that what you are saying is with all the aforementioned things going into the car, I’ll be fine to run with just fuel at the 775 area if I upgrade the injectors further?
Thanks for your time 😁
Old Dec 28, 2020 | 01:37 AM
GeorgeR_Zed06's Avatar
GeorgeR_Zed06
Yes, you can make that HP with the mentioned fueling mods. I made 780 on 50% E with the Kong ported roots blower and over 800 on 65%. Haven't checked it on meth and full E85 yet. You wont make the torque but you will definitely make the HP....
Old Dec 28, 2020 | 12:54 PM
JUICED1's Avatar
0JUICED1
Former Vendor
We have made 900rwhp with LT4 injectors/high side pump and a low side aux pump. The tuning is key but it can be done for sure.
Old Dec 29, 2020 | 02:22 AM
16 Stingray
Without meth? What were the IAT'S?
Old Jan 4, 2021 | 09:20 PM
ckassen's Avatar
ckassen
All good info above. 900rwhp would be with meth and pushing the blower to the maximum while incorporating a lot of timing. IATs aren’t much of a concern with meth, but I would imagine there may be some concern if you were running 1 mile events.
To Fueling
