C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Direct Injection Delete
Old Jun 29, 2021 | 04:17 PM
King_C7's Avatar
King_C7
Default Direct Injection Delete
Has anyone tried or thought about doing a direct injection delete?
Old Jun 29, 2021 | 04:59 PM
C7&7's Avatar
C7&7
I remember Matt at Florida Speed (no longer in business) doing this in like 2016 ish on a customers car. I think it was motorhead here on the forum actually.
Not sure how the car ended up running, but I bet it freaked out the factory ECU.
Either way you have to do a aftermarket ECU, so you might as well just add port on top of DI.
Old Jun 29, 2021 | 11:42 PM
99vetteran's Avatar
99vetteran
Why? Direct injection is a much better fuel delivery system then the LS port injection ever was or will be. Now if you want to add port injection under the blower that's different if you are planning on making a 900 to a 1000 rwhp . It would be a fu-king nightmare to even try it, but I guess if you wanna go slower that's the way to do it.
Old Jun 30, 2021 | 03:00 PM
Rdubfalco's Avatar
Rdubfalco
Old Jun 30, 2021 | 04:09 PM
99vetteran's Avatar
99vetteran
Originally Posted by Rdubfalco
Old Jun 30, 2021 | 08:33 PM
BooSSted's Avatar
BooSSted
I remember reading on a build that attempted to delete the DI. They ran into major issues tuning with the stock ecu. Keep it and just add port or build up the DI to support more fuel. Options are available finally. Big high flow injectors, HPFP, lowside and belt driven highside etc...
Old Jul 3, 2021 | 10:00 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Don't do it. Di is a much more efficiently fuel delivery platform go with Crawford Holley Port Injection which had closed loop learning with widenband O2 to 100% hit your air fuel ratio and it only kicks in when needed.
Old Jul 3, 2021 | 10:56 PM
BooSSted's Avatar
BooSSted
Beyond the piggyback fuel controllers for port, shops are starting to unlock the potential of motec with these setups. Which gives car greater tuning/control of the car. Let alone fuel control, but boost per gear, true traction control. That's why these 2K+ HP Vipers/lambos get busy with far less traction issues
Old Jul 7, 2021 | 03:32 PM
Cordes Performance Racing's Avatar
Supporting Vendor
We are deleting it on a very high hp C7 build here because DI injectors fail at a high rate and pumps can leak. Would rather focus on one solid setup at 2k hp then dual injection and have potential more issues.
To Direct Injection Delete
