C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Alky meth kit
Old Feb 13, 2022 | 10:56 PM
740tank's Avatar
740tank
Cruising
Default Alky meth kit
I have a pro charged c7 2014 stingray, put on meth kit had it tuned got it back within 1week all my clusters go to zero and I loose communication from eco and tcm. So I unhooked the meth kit ran car for about 4-5 days and it ran fine.. plugged it back in within 5 min of running it and it’s all jacked up again.. sometimes it will start sometimes it won’t sometimes it will start and no lights will come on at all and won’t even be able to move gear shifter.. then I hit the start button again and the lights come on and then I can put it in gear….also now my remote start won’t work either…. Any suggestion?
Old Feb 14, 2022 | 06:32 AM
Gary barnes 1098's Avatar
Gary barnes 1098
I would go and track down all your connections. That kit is basically independent of all your factory systems. Look at the ground that was used, maybe used a ground from your factory electronics and isn’t fastened well. Should really be something simple.
Old Feb 14, 2022 | 11:15 AM
740tank's Avatar
740tank
Cruising
yeah I’m gonna have to I unplugged it and within an hr or so the system reset itself and works fine…. Cleared the check engine lights and everything….. like it never happened
Old Feb 14, 2022 | 04:42 PM
Gary barnes 1098
Don’t sweat it. I used to totally flip out when something like this would happen. If it’s an alky meth kit contact Julio at alky if you can’t figure out. He’s very helpful and answers the phone. I’m sure he’s heard of this many times before. Just don’t get frustrated with the meth and ditch it cuz it is truly a good product and beneficial to your motor. Over the years I’ve had some problems but always figure them out somehow.And you’ll learn a lot doing it yourself.
Old Feb 15, 2022 | 08:07 AM
Random Dan's Avatar
Random Dan
Default Clean the battery and cable connection
like mine, Your car is a few years old now. I’m sure they disco’d the battery when they did all this work. I bet if you buff the battery terminals and inside the cable clamps with a green scotch-brite pad, this could all go away. I had freaky tach needle jumping like all over shortly after disconnecting the battery to do some work. Wear gloves, lead is a neurotoxin.
Last edited by Random Dan; Feb 15, 2022 at 08:11 AM. Reason: Forgot to mention what to buff with
Old Feb 19, 2022 | 03:16 PM
740tank's Avatar
740tank
Cruising
I’ll give it a try….
Old Mar 7, 2022 | 10:46 AM
Gary barnes 1098
Any update on this?
Old Mar 7, 2022 | 10:48 AM
740tank's Avatar
740tank
Cruising
Any update on this?
tried everything I could…. It’s at shop to get the ecu replaced and tuned. 🤞
Old Mar 7, 2022 | 02:31 PM
Gary barnes 1098
Cool. Good luck.
Old Mar 15, 2022 | 01:09 PM
Chazzmania's Avatar
Chazzmania
It sounds like something is going on with the ground. I am currently installing an AF/R and boost gauge in my car right now, and there are a lot of comments on different grounds being used that could cause issues.
Keep us posted on the fix action
Old Mar 23, 2022 | 02:06 PM
C7&7's Avatar
C7&7
Yea this sounds very much like a ground issue.
To Alky meth kit
