C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Maggy Upper Pulley Size VS Boost Chart
Old Apr 7, 2023 | 01:44 PM
Bruceham's Avatar
Bruceham
Default Maggy Upper Pulley Size VS Boost Chart
Anyone knows where I can find a chart showing the upper pulley size versus boost on the Magnuson TVS2650 LT1 Supercharger (01-26-62-171-BL)?
For the C7 LT1, the kit comes standard with a 110mm pulley and is rated at 8 PSI. From their website, the 8 Rib two-piece pulleys range from 110mm to 70mm.
Also, does moving to a smaller or larger pulley size require a re-tune?
Old Apr 8, 2023 | 09:44 AM
Bruceham's Avatar
Bruceham
Thanks to everyone for their input.
As mentioned above the Maggy TVS2650 C7 LT1 kit comes standard with the 110mm upper pulley, and the LT4 kit comes standard with the 90mm pulley.
The updated boost to pulley size numbers should be as follows:
I stumbled upon this excellent chart online, it seems pretty accurate:
Old Apr 8, 2023 | 11:31 AM
Corvette4ever's Avatar
Corvette4ever
Every 5mm reduction in pulley size adds 1.5-2 psi. This has been my experience
To Maggy Upper Pulley Size VS Boost Chart
